Hi does anybody know anything about thetford toilets, my daughter and son inlaw borrowed the caravan and while empting and replacing the toilet captual he had the slide piece around the wrong way and while pushing the captual in has damaged something inside but I can not work out what. The toilet now will not flush, does anybody know what the problem may be.
Cheers Mick
-- Edited by Mick on Wednesday 15th of January 2014 09:29:58 PM
Mr B2 said
09:57 PM Jan 15, 2014
Google, Thetford Toilets,
Get your model number first,
They have exploded views of their Toilets,
johnnz said
08:00 AM Jan 16, 2014
I had a flushing issue with the Thetford in my motorhome.
After storing the vehicle for several months the vanes on the flushing pump became stuck. I removed the pump which is located beneath the tissue holder, underneath the pump the vanes are exposed, I freed the vanes and solved the problem.
This happens every time I store the vehicle for a lengthy period.
Not sure if this helps or not.
Mick said
06:36 PM Jan 16, 2014
Hi Brian the model no is C 2 R A and thank you for any information you may have. Also does the toilet flush from the main pump or does it have its own inbuilt pump.
cheers Mick
-- Edited by Mick on Thursday 16th of January 2014 06:38:44 PM
Mick said
08:20 PM Jan 16, 2014
Hi sorry I misread your message, thanks for the imfo.
Cheers Mick
cheers Mick
Mick
