Over the last many months we have had trouble with our Electrolux fridge not staying cool enough in the hot weather. Alas as we were free camping at Fort O Hare in Dartmoor and having our happy hour which lasted for hours we realised that our climate class was SN which stood for Sub normal. We should have a T =tropical fridge. There are four sorts, SN, N T ST.
At last our problem is solved so off to buy a new fridge for the right conditions.
Most new vans have T fridges so for the unaware watch that.
No more will we have to be looking at the digital thermometer.
You learn something every day, which is wonderful
justcruisin01 said
09:26 PM Jan 5, 2014
Before you jump in the deep end you may be interested in reading these posts;
Enter the headings into the search window;
If you want the results then let me know, you will realise why I never made them public if you have a read.
I supplied them to about 25 members via PM & email.
JC
who has put 12 volt fans on van fridges ( 1 2 3 ) (Preview) Techies' Corner blaze 62 2637 05:58 PM Dec 18, 2012 by Webmaster
SOME TEST RESULTS ARE IN ON THE FRIDGE INSULATION. ( ) (Preview) Techies' Corner justcruisin01 15 766 05:47 PM Jan 4, 2013 by justcruisin01
KFT said
09:28 PM Jan 5, 2014
yours might work ok a bit further south(pole area)
seriously though it may make a good little beer fridge in your shed where it can get plenty of air.
frank
hako said
11:32 PM Jan 5, 2014
I'd try what JC suggests first before going to the trouble of replacing it. We insulated ours and added the fans and it really does make it icy cold.
justcruisin01 said
04:00 PM Jan 6, 2014
Well done Hako; Another member has just done his as well.
nallingtoon said
07:57 PM Jan 6, 2014
we put a fan in ours and over xmas performed well will now be putting insulation in to improve it further
Neil
justcruisin01 said
08:40 PM Jan 6, 2014
Neil
The insulation is the main part, the fans do help.
JC
chrisnchris said
10:41 PM Jan 6, 2014
I would also try JC first . Worked for us .Pie warmer to 2 degree or less fridge .Saved us a bundle
justcruisin01 said
01:53 PM Jan 7, 2014
chrisnchris wrote:
I would also try JC first . Worked for us .Pie warmer to 2 degree or less fridge .Saved us a bundle Cheers
Good one Chris, just have to putup with the cold pies; Bugger.
JC
Motorhomer13 said
01:39 PM Jan 12, 2014
What do you mean by...We put a fan in the fridge....
Please explain.
Frank
hako said
02:50 PM Jan 12, 2014
Some people actually fit a fan inside the fridge to blow over the cooling fins and circulate the cool air.....this is in addition to the external fan(s).
JC
by Webmaster
by justcruisin01
frank
Neil
JC
JC
Please explain.
Frank
