Hoping someone might be able to help. I can't get hot water to come out of mixer tap over kitchen sink (cold only) , if i turn hand basin on when hot water arrives sink is fine. All on same line kitchen tap is first in line . Thanks Geoff.
brian said
04:40 PM Jan 4, 2014
More info required.
Did it originally work OK?
Does any water come out when the mixer is in full hot water mode?
Does the hot water continue at the kitchen once the hand basin is turned off again?
If so, does it gradually go cold?
Vanderee said
06:49 PM Jan 5, 2014
Sounds like a faulty mixer tap internal cartridge. If that is not the case,
your sink tap hot water in line is hooked up wrong to the basin HW tap inlet pipe somehow.
I would check all the plumbing pipes.Shut off valves if any to by passes etc.
-- Edited by Vanderee on Sunday 5th of January 2014 07:02:41 PM
_wombat_ said
09:19 AM Jan 6, 2014
have you turned the hot water system on?
Vanderee said
07:22 PM Jan 7, 2014
Good question wombat, I think he's found the problem, no news= good news ?
brian said
07:38 PM Jan 7, 2014
I seriously doubt that was the problem, he did say that he was getting hot water at the basin. Bit hard to do that if the system is not on. Either way, it looks as though he is not coming back.
geoff allen said
09:00 AM Jan 8, 2014
Yes once the hot water starts to flow it is fine and it stays hot. could be a faulty mixer tap.Going to drop water line off to see if hot water flows to there. Thanks
