Van has been stationary for 3 weeks. Pulled out today and heard loud clankin noise underneath. cannot see anything loose. Before wd go to a caravan outlet and spend a fortune, thougt I would ask if any one has had this experience. Thanks
Plendo said
09:11 PM Jan 2, 2014
It may seam obvious, but did you have a wheel lock installed, and did you remove it?
Bunkerbob said
09:13 PM Jan 2, 2014
Clank could be a loose bit or if from the axle area, a bearing. You might need to get the cook to walk alongside while you drive SLOWLY forward to isolate the problem. Sounds like a good excuse to spend another week in the area.
elliemike said
01:01 AM Jan 3, 2014
What about jacking the Wheels up (Handbrake Off) Spin each wheel listen for loose Brake Magnet or levers. Hold the tyre edges and wiggle testing for stuffed bearings.
I had a noise about six months ago. The badly flogged out Brake magnet, had come off its actuating arm.
-- Edited by elliemike on Friday 3rd of January 2014 01:03:47 AM
2weis said
11:38 AM Jan 3, 2014
another obvious suggestion
are the leg supports up correctly
handbrake off
brian
PeterInSa said
05:56 PM Jan 3, 2014
Is your wearing parts of your WDH lubricated?
When Tug is straight ahead of your van are the chains on your WDH vertical?
patmc49 said
08:43 PM Jan 3, 2014
Thank you for your help.
It seems it was lubrication that was needed. Van was standing, for 10 months in the heat seems springs were dried out. No longer clanging just a bit squeeky.. now i need lubricating cheers.
handbrake off
brian
