I have a TV permanently mounted in the motorhome butwanted to be able to watch portable outside. I didn't want to sit it on a table or bench nor did I want to screw or bolt it to an outside wall. The solution I came up with can be mounted anywhere on a flat non-porous surface. Supports 90 kg and can be placed or removed in 15 seconds?
I attached a photo with the iPad but it obviously did not attach. I will need to crank up the computer.
-- Edited by mickm on Tuesday 3rd of December 2013 10:36:15 PM
So is it on suction pads? If so, I'm amazed that they'll hold up to 90kg. I haven't had very good experiences with things on suction pads. Maybe I've just had lousy quality ones.
mickm said
11:40 PM Dec 4, 2013
I had them on a device used to load a kayak and thought they would serve the TV use. I tracked them down to
Wassa
http://www.ebay.com.au/itm/RAM-Triple-Suction-cup-base-super-heavy-duty-suction-cup-RAP-365-224-1BU-/151161022940?ssPageName=ADME:L:OC:AU:3160
Mick
Made the link clickable
