it's amazing how clean the laser cutter can make cuts. We have one at work as well as the computer controlled break press. One drawback of the pristine cuts is that it makes it hard to paint parts because the paint tends to draw back from the sharp corners. We actually have to run a flapper disk over the corners to give them a slight rounding off so they can be painted properly. Great clip thanks for sharing. The original link was OK for me too.
Wombat 280 said
04:49 AM Nov 24, 2013
Looks like an expensive bit of gear to hang spotties and a winch on . I like the plastic ones they seem to deflect impact events without distorting the bar and don't adding to the weight on the front end
D and D said
05:04 AM Nov 24, 2013
Do you have a Smartbar, Wombat 280? I'm looking at getting one put on my beast and I'd be interested in what you think of them.
http://www.youtube.com/watch?v=ncDNzgUELXQ#t=618
Don't know what happened there Neil - I should have checked the link before posting. I have checked this one and it does work
http://youtu.be/ncDNzgUELXQ
