Have a bloody infection in my leg, off to the hospital every day to have my dose of antbiotics straight in the jugular (at least the vien in the hand), Elevate your leg they say,thats all well and good but when living in a van its not the easiest but doing alright most of the time. Still gotta pee you know. Feeling very house bound ATM, wouldn't mind a scotch about now but that's off the menu too. Just to top it off I have had a squeak in my vehicle for a day or so, today as in keeping off my feet I layed under the vehicle (keeping leg elevated of course) to have a look and found a unijoint in sad repair, another job to do.
blaze
D and D said
11:52 PM Nov 9, 2013
They reckon trouble comes in 3's ... at least they're not keeping you in the hospital. How did you get such a bad infection?
blaze said
12:01 AM Nov 10, 2013
unsure of source, no appent point of entry, cant remember the term but its unger the skin
blaze
Duh said
12:41 AM Nov 10, 2013
blaze
Hope it gets better soon blaze, the vehicle is the least of your problems with your background, but the physical body is another story.
Hopefully the anti-biotics will clear it up.
Gerty Dancer said
12:48 AM Nov 10, 2013
Ouch! Up and down caravan steps can be a pest at times like this eh? Is it cellulitis? Best of luck Blaze, hang up your leg, get your jabs and it will be over eventually.
Nelly said
02:53 AM Nov 10, 2013
You won't have to worry about the uni-joint at the moment - just need to get the leg better first - just a question how did you keep your leg elevated when under the vehicle?
hako said
03:51 AM Nov 10, 2013
Re the squeaky universal joint - you could try saturating it in WD40 or similar but what I'd do is get a few handfulls of grease and massage it in and around the joint...squeeze it in tightly around the joint just like when greasing a wheel bearing race in your hand. This should force a bit of grease into the needle bearings and give you a few more miles. This admittedly is messy but when you need breathing space it can help.
Re the leg infection I can relate...they are hard to get rid of for some reason or other....a doc mate of mine told me that it's because if the very minimal blood flow to the leg. Bits of your body that heal the quickest have the best blood supply.
Good Luck.
Bryan said
06:19 AM Nov 10, 2013
Great advice regarding the universal joint Hako. It will give Blaze breathing space at the very least.
blaze said
07:22 AM Nov 10, 2013
the docs happier enough with the pace the legs coming on, step are a real bummer.
The uni joint is past a massage. Will order parts on Monday but they will be on broome time.
thanks to all for the well wishes
blaze
07:55 PM Nov 10, 2013
blaze wrote:
unsure of source, no appent point of entry, cant remember the term but its unger the skin cheers blaze
Hey blaze - did you have that scotch after all
Hope your leg comes good pretty soon!!! Take care!
-- Edited by jules47 on Sunday 10th of November 2013 07:56:13 PM
blaze said
06:31 AM Nov 11, 2013
touch typing in the dark jules where I cant see the letters, off the drip now and onto the pills. I am guessing my scotch is still a week away.
Just gotta sort my uni out tomorrow now.
blaze
Duh said
06:47 AM Nov 11, 2013
Well I hope it's not from stepping on a piece of sharp coral chasing those nude belles down on the beach !!
06:12 AM Nov 15, 2013
The Scotch is for the leg ??? Right ?? Lol..
blaze said
11:21 PM Nov 16, 2013
Always to be taken orally but some say a really good scotch will absorb through the skin just as well
ps
back on the leg again but still a little sore
blaze
JRH said
11:28 PM Nov 16, 2013
ps
blaze
Use the Scotch to heal the leg from the inside, it is the only way to go. Good Scotch must be taken orally and not used as an embrocation.
04:53 AM Nov 18, 2013
Try some manuka honey ?? Work mate fell through a air conditioning hole in floor and badly opened up his shin..
Didn't heal .. Tried antibiotics etc.. A Chinese Dr wrapt it in some iodine solution and honey .. Within a week the wound was healing big time..
blaze said
05:18 AM Nov 18, 2013
have seen that work before myself , troublw being I have no point of entry for the infection. Coming good now
blaze
Cruising Granny said
06:43 AM Nov 18, 2013
blaze wrote:
have seen that work before myself , troublw being I have no point of entry for the infection. Coming good now cheers blaze
Wow, I can really relate to your painful leg. In the tropics years ago we found bathing the wounds in hot water with vinegar did the trick. The water has to be as hot as you can tolerate. The tropics doesn't help healing, and the old advice of walking in the sea water doesn't apply either, because the water is too warm, and their are some foreign enzymes in it which can make it worse.
I don't know who's going to fix your vehicle, but I found Walcott Street Autos very quick, helpful and didn't charge like a wounded bull. I left Broome in 2007, and I've no idea if they're still operating, but I'd recommend them.
blaze
blaze
Good Luck.
blaze
blaze
ps
blaze
blaze
