I have a rear view camera on my van and use RCA plugs to connect between the van and the tow vehicle, now for the second time with replaced fittings I have had a wire break away on the tug end. the plug is held in a bracket and I have used a fairly heavy multi strand wire I am wondering if there is another plug that i can use more effectively than an RCA plug
Any help would be appreciated.
Keith19837 said
01:35 AM Nov 7, 2013
This may be a dumb question; but is there enough wire to allow for 'stretch' when turning or am I on the wrong track?
aussietraveller said
02:57 AM Nov 7, 2013
thanks for your response Keith the lead for the Camera is attached to the caravan wiring 12 pin plug cable with an extra length that would allow for a bit more than turning stretch so this should not be an issue but I will double check.
D and D said
03:06 AM Nov 7, 2013
Now I'm confused - is the connection between the van and the tug via an RCA plug and socket or through the 12 pin plug?
Keith19837 said
03:20 AM Nov 7, 2013
This has got me 'ordinary'. Next dumb question; are the individual cores fully tightened in the respective sockets? I can't think of anything else. Maybe some more technically minded (which is pretty much everyone) person here can solve this.
hako said
06:25 AM Nov 7, 2013
Tape (wrap) the camera cable to the (stiffish) caravan cable and then attach the camera wires to spare pins in the van plug. Next at the tug end, connect the monitor wires to the corresponding pins you've used for the camera.
The reasoning behind this is that the caravan cable is pretty stiff and does not flex much. At the tug end there is no flex as the wire is in the socket. With 12 pins you should have a few spares.
I think it would work.
04:49 PM Nov 7, 2013
The Camera lead is connected using an RCA plug and socket, I have taped the wires from the van camera onto the outside of the Van 12 pin plug and wiring loom so that it was supported then near the plug the wiring for the camera separates and goes to a separate RCA socket.
I thought about running it through the 12 pin plug but was told I would pick interference as I run the van fridge on 12 volt whilst travelling and possible interference from indicators and stop lights I am open to advice from experienced members on this one
_wombat_ said
05:13 PM Nov 7, 2013
RCA plugs should not be used for exterior fittings, go to Jaycar and tell them what you have and seek their advice, they will have what you need, maybe even tricky dickie will have something.
D and D said
11:01 PM Nov 7, 2013
Mate of mine has a reversing camera and two side cameras on his van and connects to the tug via a 7 pin plug and socket that are bolted onto the A frame and the tug with and extension cord between them - he's had it like that without a problem for a couple of years now.
PeterS said
07:30 PM Nov 8, 2013
Our camera is connected through the 12way plug with all the other electrics and we have no interference at all.
Peter & Jan
06:59 AM Nov 9, 2013
Thanks I will try through the 12 pin appreciate all the information.
Peter & Jan
