This morning decided to have brekky in Miss Daisy,turned the toaster and kettle on at the same time. Oops no power. Looked at the converter, the red light was on so figured that was all OK. Came back into MD and started switching things in the powerboard. Still nothing. Ok, now lets go back to step one, ohhh lookie there, the master switch was off on the converter, durrrr, now that was back on I had to figure out if the switches that I had been playing with were actually on or off. Finally got it all figured out and all working again, and took it one appliance at a time to have toast and tea.
A classic case of over thinking the obvious by somebody who knows very little about that sort of thing, but is learning very quickly. Gotta love my new life and learning about things that I never thought I would have to know about or deal with. Actually half of it I did not really know even existed.
I think this might be called growing up. Bugger.
06:13 PM Oct 19, 2013
Never grow up Sharon - just grow older and wiser!!!!"
KFT said
06:15 PM Oct 19, 2013
G'day Shekon, you took the right approach by turning things off first.
with these sorts of set ups you do have to be conscious of the load you are switching on.
now you know a bit more it probably wont happen again heh.
frank
yeoeleven said
09:01 PM Oct 19, 2013
You will get used to it, I have none of those problems having systematically got rid of 240 volt appliances.
Very simple is my life without 240 volt requirement but then without some conveniences, if I want toast I have to use the griller on the gas cooker so rarely do I have toast.
Keep it up Sharon and hope to catch up with you at Green's, John
done dreaming said
04:53 AM Oct 20, 2013
i'm hearing you with all these fancy contraptions.whats a toaster???? someone who raises a glass????
shekon said
05:37 AM Oct 20, 2013
Arrrrrr..... That is where I went wrong, I needed the glass.
frank
