An ideal solution for holding down shade walls etc...when you can,t quite reach the ground is to use large plastic ties ,very strong and adjustable .OK if u are staying for extended period. Ties are available that undo, no need to cut them.
12:18 AM Oct 14, 2013
Do you mean cable ties? We have some really long ones, but they have to be cut off.
bloomoon said
05:27 PM Oct 14, 2013
Hi, if you have thicker ones(large) you can release them with a small flat screwdriver. Just lift the tab in the centre.
