Have just developed a creaking in the van floor when walking on it we have a van with front kitchen and door at the front as in my avitar, this noise is driving my wife nuts so any help in fixing this would be greatly appreciated.
justcruisin01 said
02:15 AM Oct 8, 2013
I have heard of this before , I think their fix was to have one climb under the van while the second walkes around untill you pinpoint the creaking section. I believe a small timber wedge or two was then fitted between the floor & the chassis &/or crossmembers in that section.
JC.
KFT said
04:18 AM Oct 8, 2013
we had the same problem in our millard
the noise was coming from a joint in the flooring. I got Mrs KFT to walk on it while I was under the van so I could pinpoint the location.
Once I knew where it was I filled the joints and the gaps with liquid nails and stayed off the floor until it set.
problem gone.
frank
05:23 AM Oct 8, 2013
A more common reason for the floor creaking than chassis support is furniture not being secured securely to the floor. I was shown this to be the case in my van. The cure is to tighten the existing screws and add extra screws.
_wombat_ said
03:58 PM Oct 8, 2013
problem gone.
frank
I might do the walking bit and get Mrs W to go under the van, I don't like heights.
patrolst said
12:47 AM Oct 9, 2013
We had the same problem in our Regent, I layed under the van while it was on stands and ran "Sikaflex" around both sides of all the chassis framing that came in contact with the floor, this was done 12 years ago and since it was done we never had any more squeaks while walking on the floor.
I even removed the water tank so no section was missed.
It took a while but well worth the effort.
_wombat_ said
01:05 AM Oct 9, 2013
do you want to come and do mine, Mrs W will not get under the van, I will never understand women ()
patrolst said
02:33 AM Oct 9, 2013
I did it once, now I just explain how I did it
_wombat_ said
02:49 AM Oct 9, 2013
Does that mean no.
villatranquilla said
03:00 AM Oct 9, 2013
this trip we developed a creaking floor near the en-suite after a few days on the one site . Fixed it by re-adjusting the drop down legs.
patrolst said
03:06 AM Oct 9, 2013
Kinda yes
_wombat_ said
03:19 AM Oct 9, 2013
patrolst wrote:
Kinda yes
Hmmm, 'Kinda', so there is some hope that you can do mine?
aussietraveller said
12:55 AM Oct 10, 2013
Thanks guys for the advice I will give the resealing of the floor to the metal joist a shot and hopefully problem will be solved.
Could Mrs Wombat please come and walk on my van floor as I to am scared of heights especially when its jacked up so I can crawl under.
_wombat_ said
01:04 AM Oct 10, 2013
You are bloody brave, have you seen the size of Mrs W
Dunmowin said
02:41 AM Oct 10, 2013
I will be interested to follow this thread. We also have a developed a creaking, just forward of the front axle. The only difference is that it is driving Mr D mad. Me, I just ignore it. Mr D has done the sikalfex thing, but still creaking. Maybe more attention is required along these lines.
JC.
problem gone.
frank
Does that mean no.
Kinda yes
