Hi all i have just bought 2x60 watt second hand panels with a cmp12 regolator will this reglator work with one panel or has it to be conected to the both to make it work cheers snap
-- Edited by snap1946 on Saturday 5th of October 2013 07:36:42 PM
justcruisin01 said
03:49 AM Oct 6, 2013
Not familar with the term CMP12, does the 12 indicate that its a 12 amp capacity?
If so it will handle both or just one if you wish. The main point to be sure of with any system is that the regulator is capable of handling the max amp output of all panels attached.
snap1946 said
04:02 AM Oct 6, 2013
not sure it says cmp12 12/24v 10amp
thomas01 said
05:08 AM Oct 6, 2013
Snap
CMP12 is a common regulator. It can be used with 1, 2 or more panels as long as the total input current is less than the rated 10 amps. With the panels you currently have there should not be a problem. Less panels mean less input current to charge the battery but will still work.
snap1946 said
06:32 AM Oct 6, 2013
THANKS ALL FOR THE ADVICE
-- Edited by snap1946 on Sunday 6th of October 2013 06:33:22 AM
Hi all
cheers snap
Thru the magic of Google......
.. Lots of results for CMP 12
... This is from the first result that I got.
Hope it helps. G
http://www.jutasolar.com/en/product_more.asp?id=1185
© Harbin Hopeful Star Co.,Ltd. www.jutasolar.com ICP08000351
Website producer group :www.hiwebsite.net
