Had some stickers leave residue on plastic when we took them off. This resulted in a very ugly look, area always looked dirty. Also had some "silastic" type stuff on the laminate in the kitchen. Tried a few things to remove the sticky residue as well as the "silastic" - WD40, eucalyptus, elbow grease, none of which worked.
Got a product called "OOMPH" from Bunnings, $6.95 for small spray bottle - works a treat - removed the sticky residue, as well as the silastic, wich also required a bit of scraping with a piece of flat plastic.
06:10 AM Sep 26, 2013
Tonight I used Eucalyptus Oil on my van Jules
Where I'd taken the decals off I had been left with sticky residue which came off easily with the above.
Now I've got to polish Myrtle and get new decals.
pambaz said
02:12 AM Sep 27, 2013
We use Big Kevs Goo remover not sure if it's still available though I bought it a few years ago in Woolies. Removes lots of stuff even chewing gum.
Other than that Eucalyptus oil.
03:51 AM Sep 27, 2013
Tried eucalyptus oil on the sticky stuff and it didn't budge it. Same with the "silastic" nothing worked till I got this stuff. Didn't know you could still buy Big Kev stuff.
Kiwozzies said
12:58 AM Sep 29, 2013
Use a product called De-Solv-it 125 ml will go a long way, this will also remove stubborn stickers from windows.
I think Bunnings have it in the cleaning section.
copper1 said
03:59 AM Sep 29, 2013
WD40 is the best goo remover going and what home/caravan does not have a can try it, you will be impressed.
johmandkaz said
02:43 AM Sep 30, 2013
Orange goo remover from woollies, coles or iga, is brilliant, it also removes stains from vinyl and vehicle paintwork.
02:45 AM Sep 30, 2013
Copper1 - tried the WD40 - didn't work on this stuff!!!!!!
Gerty Dancer said
07:47 PM Oct 1, 2013
Got a problem with a sticker I cant even get a fingernail under an edge its so well stuck. If I use a blade I'm scared of scratching the fibreglass. How can I shift it?
Edit... its a dealers sticker.
-- Edited by Gerty Dancer on Tuesday 1st of October 2013 07:50:57 PM
02:53 AM Oct 2, 2013
Hairdryer Rosie - heat it up and it will start to lift - any residue, plenty of ideas above!
Gerty Dancer said
03:21 AM Oct 2, 2013
I'll give it a go Jules, thanks.
Gerty Dancer said
04:13 PM Oct 4, 2013
Nope... its still absolutely adheres to the caravan. I scratched a bit off, and found that the colour has soaked through into the fibreglass, plus its marked from scratching. I think our best bet might be to find another sticker and cover this one. The Ooomph easily shifted the remains of another sticker though, thanks Jules.
Would advise anybody with Jayco dealers stickers on their van to remove them while the van is new, as they are permanent when sun-baked.
Cupie said
08:24 PM Oct 9, 2013
To get rid of the residual after pulling off stickers ... I use fly killer aerosol .... Just hold it close to the surface & spray it on, leave for a minute or so & wipe off. Works a treat.
Haven't tried it on silicon though.
herbie said
08:00 PM Oct 10, 2013
Have also used hair spray and it works a treat...hate to think using this stuff long term must do to ladies head and hair .
Olley46 said
10:17 AM Oct 13, 2013
Another thing is one of those small steamer,s ,I took stickers of the back of my van with ease.
Lance C
-- Edited by Olley46 on Sunday 13th of October 2013 10:18:31 AM
Triple333 said
01:10 AM Oct 22, 2013
Wd40 is good too. I used it to remove advertising stickers on my car doors. Work a treat, no damage to paint work either. But I prefer the smell of eucalyptus oil.
idexnz said
05:36 PM Dec 27, 2015
After removing the sticker with a hairdryer, remove the sticky residue with diesel. Our daughter uses it often in her work and swears it does a better job than other remedies. Doesn't harm the paintwork either.
Lance C
