I have purchased a Powertech 380w inverter for my van. The only convenient place I can find to mount the inverter is under an overhead cupboard. Is it ok to mount the inverter upside down?
Cheers Pete
Bent Axle Bob said
05:04 PM Aug 11, 2013
Shouldn't be a problem. The only moving part is the cooling fan and that runs in a bearing. I ran mine mounted on a wall and had no problems. As long as you can access the unit easily and air can circulate , it should be happy
justcruisin01 said
09:37 PM Aug 11, 2013
Cheers Pete
I would be mounting it close to the battery pack, no voltage drop.
JC
Ontos45 said
06:13 PM Aug 12, 2013
As all above, I mounted mine on a wall but also, as the units fuses were internal, I mounted an external fuse block with fuses adding up to just under the ratings on internal fuses. EG. mine 70 amps so externals where 65 amps. No pulling unit off wall to mend fuses, and they do go. Chase fault before changing though.
Baz421 said
06:38 PM Aug 12, 2013
justcruisin01 wrote:
Cheers Pete
JC
Once again JC is100% right
allinone said
12:43 AM Aug 13, 2013
I mounted mine according to the manufacture recommendations, from memory only one way was not recommended. Read the manual for some tips.
wasn_me said
02:19 PM Aug 14, 2013
Thanks for the replies. The position I would like to mount the inverter would require 2 mtrs of cable. I would use 6mm. Would this cause voltage drop? I will only be using it for recharging laptop, & camera batteries. (When the solar is supplying excess to battery charging)
My battery is under a bed. The inverter couldn't be accessed easily if mounted here. What do you do in this situation?
I have seen inverters mounted beside the battery in the boot & 240v leads running into the van. This seems impractical to me.
Cheers Pete
03_troopy said
01:48 AM Aug 15, 2013
If you are talking 6mm auto wire I'd consider it a bit on the light side. I'd go for at least 6B&S if I were fitting it.
wasn_me said
06:33 PM Aug 16, 2013
Hi Troopy, The wire is marked as 6mm. It measures 4mm dia of insulation, 3mm dia of wire. By my calculations that's approx 7sq mm for the wire. Wire sizing seems a confusing issue. It would be good to get a chart that cross references the sizes.
Cheers Pete
oldtrack123 said
08:50 PM Aug 16, 2013
Cheers Pete
Hi Pete
That is a Auto cable size = about 9B&S
Always be wary when the size is just in mm
It has no relaitonship to actual copper core size!
Cheers Pete
JC
Cheers Pete
Cheers Pete
Hi Pete
6B&S= 13.3mm2
PeterQ
This may help.
http://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html
Thanks for the replies. Patrolst, I've saved your link for reference.
Cheers Pete
