To take the work out of maintaining your cast iron cooking equipment
If you leave the left over cooking grease and oil on your equipment it will form a layer of protection against rust.
But if you like to keep things nice and clean, try placing a layer of aluminium foil on the hotplate first for a easy clean up.
When finished cooking just throw away dirty foil.( bin it not throw it into the bush)..
kww511 said
05:04 AM Jul 27, 2013
Foils good, baking paper is better. Much more easily biodergraded
the rocket said
04:56 AM Aug 14, 2013
thanks for the tip. kind regards.
herbie said
02:10 AM Aug 15, 2013
We find using baking paper doesn't hold the heat like the Al-foil does.
The baking paper also can catch fire very easy if it touches any heat.
moamajohn said
02:39 PM Aug 31, 2013
We purchased a couple of sheets of that black plastic looking stuff from a country market.Fantastic to use on the hotplate or grill when you may need to use a dodgy c/park BBQ,just wipe it and roll it up till next time.
sandsmere said
02:52 AM Sep 1, 2013
We got some of that too Westy .
$18 at Bunnings and still going strong after 2 years .
grahos said
08:37 PM Mar 17, 2014
Yes I have used the black sheet many times and it is still working fine.
03_troopy said
06:49 PM Apr 8, 2014
We got some sandwich bags made of the black teflon stuff too. I used to use them to toast my sandwiches in the toaster at work. You get some funny looks when you put a cheese and pickle sandwich complete with bag in a normal toaster though.
