A good cheap way to help keep the cold or heat out of your C/Van or Motorhome is to use bubble wrap on your windows .Use Blu Tack or even Velcro to keep it on. It will cut the temp down or up depending how hot or cold it is. Can buy it in rolls at post office or even those office supply shops or maybe via the net.
Sheba said
03:23 AM Jun 14, 2013
Hi Herbie. Would that be more efficient than the Silver Windscreen Shield thingies that I've been using ?
jimricho said
03:46 AM Jun 14, 2013
Would that work on my rig???
sufil said
04:21 AM Jun 14, 2013
We have cut up the alfoil/silver windscreen thingies to fit each window. We attach ours with Velcro. Roll up and chuck under bed when not being used.
herbie said
06:43 AM Jun 14, 2013
I have been meaning to post this idea re the use of bubble wrap for some time,but just remembered it today for some reason.Why I mention it to be a effective cheap way to help keep your van warmer/cooler is that I had to go to one of those dreaded energy saving seminars through work and some you beaut professor on climate change was giving a talk and demo regarding the bubble wrap and was saying it is used a lot now over in the colder underdeveloped parts of the world.So I asked him re the use for RVs and he said it sure would help a lot. One of the blokes I work with has put it on his Hi Ace camper and is wrapped with it.he also uses the silver window shield thingo's as well. I know also of a solo coaster owner who has sown the bubble wrap between block out pieces of curtains , kind of like a sandwich curtain/bubble wrap/ curtains. Must ask her how it has worked.
Wombat 280 said
03:35 AM Jun 16, 2013
Street dwellers use it when they can get it, just like the old newspaper under your cloths
Cupie said
10:03 PM Jun 20, 2013
During a particularly hot XMAS week some years ago the local servo had an additional supply of bagged ice.
They kept it cold by covering it with sheets of a bubble wrap with shiny foil on both sides.
After New Year when all the ice was sold, there were a few bits of the insulating sheeting lying around.
They were happy for me to take it away.
Used it to make an insulating cover for my Engel. Wish I had more for the windows.
GaryKelly said
03:08 AM Jun 21, 2013
How about using two sheets of foil with bubble wrap in between, like a sandwich? Use spray on adhesive on one side of the foil, stick the bubble wrap to it, then stick the second piece of foil on top.
Hoodathunkit said
06:53 PM Jun 21, 2013
Or you can buy silver foil bubble insulation see link . I have heard that some people insulate the canvas/vinyl area of the poptop caravans with a strip of this type of foil.
I used that Blue one side and silver the other wall covering that builders nail to the timber frame before bricking up.
It worked marvels for us to reflect the heat especiall from the roof hatch.
Jay&Dee
05:44 AM Jul 1, 2013
I used foam insulation they use on floating floors .. Its $32 a roll at Bunnings.. Have used it between lining and vinyl covering inside.. When re-covering inside bus/ motorhome..I think its better than fibre glass as it holds moisture which promotes rust.. It could be used on windows if required ?? We already have the reflective panels that go up at night for front window etc.. We don't need any more accidents on the road now do we ?? Aha..
Sheba said
03:05 AM Jul 6, 2013
Thanks for the Link Hoodathunkit. Bought 2 rolls, and it came within the week.
JayDee said
09:12 AM Apr 22, 2018
Update
We have purchased the sun block shades for car windscreens. I have placed a channel strip above each window. Mrs Dee then cut the shade to the size of windows then she sewed a piece of material to the shade and then rope to the material so it would run through the channel. It is kept in place with strong elastic around each window.
Bubble wrap also attached to inside of each window.
Just our idea.
Jay&Dee
10:10 AM Apr 22, 2018
For the roof ? Solar ? I have seen fibreglass made from existing roof as template . Then mounted 80mm or so higher from roof . Can be made strong engought to carry cargo . Nothing insulates better than a cavity or airspace .
hako said
08:30 PM Apr 23, 2018
Totally off-topic but reading down this thread I came upon GaryKellys input to this thread - what a great bloke he was, heaps more GNs that have passed away too. It was great to have known them however remotely.
Good Luck.
Radar said
08:45 PM Apr 23, 2018
Good Luck.
How right you are, had some good input with Gary, he made me feel very lucky. Rip Gary.
http://www.ebay.com.au/itm/SILVER-FOIL-BUBBLE-INSULATION-4-M-LONG-750-WIDE-FOR-HOT-OR-COLD-CLIMATE-/281123740565?pt=AU_Business_Industrial_Construction_Building_Materials_Hardware&hash=item417447db95
Jay&Dee
Update
Just our idea.
Jay&Dee
Good Luck.
