Any ideas on what to line cupboards with. In the past we have used soft plastic mesh and find it breaks down and goes soft and sticky. We also live in a hot climate.
Gerty Dancer said
02:17 AM Jun 2, 2013
Welcome to the forum Poodles Parents. We used that stuff too with the same result, so we tried out some other types and found that the more expensive stuff is longer-lasting and thicker. Its still worth it to save having your stuff from sliding about I think. One thing that works ok but still allows a bit of sliding is to line them with those cheap terry-towel tea towels.
poodles parents said
05:37 PM Jun 2, 2013
Thanks for you reply. Will try your suggestion. Cheers Rondel
neilnruth said
12:12 AM Jun 3, 2013
Terry towels would be good because you could wash them to freshen them up.
Cupie said
08:03 PM Jun 4, 2013
I usually get the prettier non slip matting rolls from spotlight ... when there's a sale on.
Have been using even the cheap stuff for around 15 years & never had a problem.
Only change it if it becomes drab or dirty, although I have washed & re used some bits.
I'll drop in to Aldi on my way past tomorrow & look at their offering.
-- Edited by Cupie on Tuesday 4th of June 2013 08:04:57 PM
12:06 AM Jun 5, 2013
Saw some really good looking stuff at Aldi yesterday - no holes in it - sort of a thinner version of yoga mats - about $4 I think, in a roll. The grip stuff with holes, lets crumbs and stuff through - these more solid ones could be easier to clean.
neilnruth said
03:34 AM Jun 5, 2013
I find the tins in the pantry leave rust marks on the non-slip stuff so at some stage it will have to be replaced.
jetnomads said
10:16 PM Jun 7, 2013
I use non slip in some cupboards but in deep ones where I need stuff to be able to slide to get it in and out (eg appliance and plastic storage boxes), I use chap vinyl from Bunnings. cut to size. Easy to clean, can be replaced if necessary, keeps the cupboard bottom in good order.
aussietraveller said
11:28 PM Jun 7, 2013
Like jetnomads I have purchased some reasonable quality vinyl on the bottom of cupboards and on benches the non slip matting and if dirty or damaged can be easily replaced, also use stubby holders to protect glasses and mugs.
