Finally got around today to using my Aldi sim card in a new phone.
Rang Aldi (interesting experience, at least the music wasn't bad, but the wait was long). Asked if I could use the phone number which came with the (locked to Telstra) phone, or whether Aldi would give me a new number (I'm happy either way).
Oh, said the Aldi lady, you can't use a phone locked to Telstra, it has to be an unlocked phone. Told her that was NOT what I had read on the net. She replied that "that's what we are told" (her tone of voice lacked conviction).
So . . . have any GNs managed to get connected with Aldi through a locked Telstra phone? And if so, did you have to change your number?
Cheers, Tony
allinone said
04:21 AM Apr 20, 2013
Aldi works on Telstra part of network and yr number can be ported even on a locked to Telstra 3G phone. I too will be churning there soon, no ALDi in Tasmania....
jetj said
05:14 AM Apr 26, 2013
I'm using a different provider who uses the Telstra network with a phone locked to Telstra without any problem.
herbie said
08:46 PM Apr 26, 2013
Has anyone used this Aldi phn set up away from the major built up areas yet ? Was just wonding if the service is any good in the out of the way places.
Olley46 said
11:23 PM Apr 26, 2013
Try googling the area map that they cover,from Adelaide to Cairns right along the coast ,Perth and around the bottom Albany Esperance ,and a couple of odd spots along west coast Darwin , Alice springs , and that's about it. .
Bucko said
02:22 AM Apr 28, 2013
I've been on Aldi for the last 4 weeks, city and country, works fine in all areas so far, no problems at all, just put it in the phone and also used in the Telstra modem foir broadband, perfect and a lot better rate of data allowable than Telstra. I've used a locked Telstra and unlocked phone as well, worked in both.
Hydeeeho said
01:19 AM Apr 30, 2013
Yep I have used and set up 2 Aldi SIM cards plus ported two numbers, it all works just fine
Cruising Cruze said
02:54 PM Apr 30, 2013
won't work in country area's that's what we find out
it is what it is Monto fine but Eidsvold no go at all , you have to be lucky where you can get connection also my phone is not "next G" maybe that is the problem
Cheers, Tony
