My fridge is 11 years old and is not working as good as it use to(like most of us).Do they need re gassing?? Seals seem ok.Cheers
justcruisin01 said
10:10 AM Apr 12, 2013
goldcoaster wrote:
Hi all,
There is no regassing as such, if it has a leak then it wont work at all.If the gases have leaked then its most likely better to replace the fridge rather than repair.
Some times a bit of rust/scale can block the tubes, the old trick is to take the fridge out & roll it around a few times turn it upside down for a while & retry unit.
If its a caravan fridge then you mat wish to have a look at this/ go to the search window & enter( who has put 12volt fans on fridges).posted by Blaze.
Then also enter ( some test results are in on fridge insulation). Posted by myself.
Mine is now working extremly well after to modifaction.
JC.
-- Edited by justcruisin01 on Friday 12th of April 2013 10:18:09 AM
goldcoaster said
04:27 PM Apr 13, 2013
Thanks JC,
I might start looking for a new one.
11:21 PM Apr 14, 2013
If you go for a Dometic one, don't get one of the round fronted ones. They are not T climate rated.
snap1946 said
01:13 PM Apr 18, 2013
do you want to sell your old one and how much
snap
goldcoaster said
01:49 PM Apr 18, 2013
I will shop around and let you know, have your details. Also tossing up whether to upgrade the motorhome. Thanks for the offer.
Hi all,
JC.
Thanks JC,
snap
