Being a female, new to this area and need to clean out the water tank. Pse help, dont no where to locate the bung to flush out water on our freedom jayco. Thanks in anticipation!
12:56 AM Mar 22, 2013
Usually at one end of the tank dibbers maybe at the outer end. I stand corrected though.
blaze said
02:45 PM Mar 22, 2013
most dont have a drain bung, just undo the lowest hose. cheers blaze
spida said
03:34 PM Mar 22, 2013
A van or motorhome? My van has a bung to undo on the tank.
Duh said
02:13 AM Mar 24, 2013
Should have a bung like Doug said somewhere around the bottom of the tank underneath, if a used van it may have been replaced by a tap.
I have also had one like blaze said where there was none and I had to undo the clip on the hose which attaches to the tank and drain it that way.
blaze
