Maybe of interest to someone here....cut and pasted from imotorhome.co.au Issue 19
The 2012 Fiat Ducato radio
can be reset to stay on for
3 hours while stationary. I
own a new 2012 Winnebago
Birdsville which had the
same problem, so I Googled
and found a UK Fiat forum
website with the answer. I
can't understand why local
motorhome manufacturers
using the Fiat Ducato haven't
got onto the remedy and reset
the radio in the factory. Here
is the remedy copied from the
website.
Turn radio on using central
power button
Within 15 seconds,
simultaneously press FM
AS and preset button
2. Each time this pair
of buttons are pressed
the display will alternate
between NORMAL POWER
MODE and CAMPER
POWER MODE
Ensure CAMPER POWER
MODE is displayed, then
press MENU
Using the UP and DOWN
button now changes the
display to show various
adjustable items. Cycle
through the options until
RADIO OFF and a number
of minutes is shown on
the display. This will take
approx. two presses of
the UP button or seven
presses of the DOWN
button.
With RADIO OFF shown
on the display press the
LEFT or RIGHT button.
Each press of either button
will alternate the number
of minutes shown between
180 and 0
With 180 showing on
the display the setting is
complete and three hours
of radio operation should
be possible. Press the
POWER button to exit the
menu and return the display
to its usual view.
Please note that in NORMAL
POWER MODE the same
subsequent steps detailed
above can be followed,
to choose between 20
mins and 0 mins of radio
operation.
website.
power button
Within 15 seconds,
MODE and CAMPER
POWER MODE
Ensure CAMPER POWER
press MENU
presses of the DOWN
button.
180 and 0
With 180 showing on
to its usual view.
POWER MODE the same
operation.
