How do you remove the 3 way fridge in a Viscount caravan
do you only have to remove the screws in the front surround panel or do you have to do more,
is there maybe a website that shows you how to do it
any help would be fantastic
12:06 AM Dec 23, 2012
There are screws in other places in a few. Do you still have the operators manual for it? The installation instructions are in it. If not, supply us a model number we can chase up a handbook.
justcruisin01 said
05:09 AM Dec 23, 2012
John, If this relates to the work I done here I did not remove the fridge, was able to do it all from the two air vents. RE- 12volt fans( closed)
JC.
Cruising Cruze said
06:19 AM Dec 23, 2012
First of all Thank you Peter D
silly I've dowloaded one a while back when I've got the caravan ,
but never gave it a tough Peter
Thanks anyway
Cruising Cruze said
06:23 AM Dec 23, 2012
@ justcruisin01
will talk to you when you back in a week of so JC thank you
enjoy your time away mate best wishes
thanks for the photo's
hako said
06:54 AM Dec 23, 2012
Dunno if Cruising Cruze got the answer he/she wanted but if not you will find 2 or 4 bolts under the floor which hold the base of the fridge to the floor (2 or 4 depending on quality of instal). They will probably be either rusted or coated in bitumen. Also need to disconnect 12V wiring and gas line.
turbopete said
05:15 PM Dec 24, 2012
if you want to remove the frig from the van check to se if it will fit thru the door otherwise take a window out
JC.
Thanks anyway
@ justcruisin01
