Can you use your battery while you've got your solar panels charging them ????
or do you have to disconnect the solar ??
11:26 PM Dec 8, 2012
Hi John. Yes you can use them at the same time. Some leave the solar panels connected all the time in their camping spot and use it as necessary. It was all happening at Greens Lake. Hope you both are well.
justcruisin01 said
06:13 AM Dec 9, 2012
All panels mounted on roof tops are permantly connected to the batteries so the answer is yes.
Cruising Cruze said
04:24 PM Dec 9, 2012
Thanks for that
was not sure the voltage is always a bit more when on charge
Peter_n_Margaret said
07:55 PM Dec 9, 2012
In fact the more power you use while on charge (compared with when off charge), the better it will be for your batteries.
Cheers, Peter
oldtrack123 said
11:10 PM Dec 12, 2012
Cheers, Peter
HI
And by that Peter means "make hay while the sun shines"
03_troopy said
02:51 AM Dec 13, 2012
Cheers, Peter
HI
Or crack out the slushy machine and make frozen Margaritas....... hic.
oldtrack123 said
04:54 AM Dec 13, 2012
Hi Troopy
We are in fine form tonight
Not too many frozen Margaritas ,now,
Even though making them did not pull the battery down
HI
Hi Troopy
