Can anyone please give me suggestions on cleanningtelford cassette toilets plus keeping the odour down please, what do other people do? Thanks..
Cheers, Have a great weekend everyone...
villatranquilla said
07:22 PM Sep 15, 2012
Hi Ellice - we use the blue aquachem and have never had a problem with odour. We use public toilets when available but the on-board loo is used at night and when travelling for both jobs (1s and 2s) - lasts at least a week before it is emptied - sometimes longer
07:34 PM Sep 15, 2012
We use the home brand nappy soaker, 1 lidfull directly into the cassette when emptied, and every couple of days thereafter - no odours, and breaks it all down pretty well.
You can also use citric acid - available in the cooking section of supermarket - half the container in water, swirl it around and let it sit - gets rid of the crystallisation etc.
KFT said
03:23 AM Sep 16, 2012
We use the nappy soaker as well and it works a treat- the thing is as there are no "chemicals" in the mix I dont feel bad about emptying it in public toilet if I really have to.
A few drops of eucalyptus oil will fix any odour problems
frank
gypsy rover said
12:28 AM Sep 17, 2012
I also use the nappy soaker, really surprised at how well it works. No odours at all. It is Woolworths Homebrand Nappy Treatment Plus. I believe some brands are not as effective as others. This one works a treat.
Chris
02:54 AM Sep 17, 2012
It seems the cheaper ones work better than the more expensive, for some reason.
Ellice said
04:18 AM Sep 17, 2012
Thanks everyone, I have tried nappy soak but did not have a lot of luck so have started citric acid to remove scale and odour, then i will try some of these others...Thanyou all again Cheer;s Have a wonderful week whereever you maybe.....
Oma said
12:23 PM Sep 22, 2012
Agree with all the Napisan posters & Ellice after a few empties/napisan use you will find that there will be NO scale on the inside of your casette AT ALL . I dissolve 3 dessertspoon in about 500 ml hot water then into cassette. If not emptying toot by 4th day drop a spoonful in. If I remember I add the Eucalyptus but only for the pleasant gum smell! It really is a wonderful,cheap effective way to keep toot clean. We went off the chemicals 5 years ago when first read about this on CF
Hi everyone,
Can anyone please give me suggestions on cleanning telford cassette toilets plus keeping the odour down please, what do other people do? Thanks..
frank
Chris
