A. securing diesal jerry can to the draw bar of the van next to the gas bottles?
B. Placing them on the back bumper of the van?
My choice if legal is on the draw bar
PS. it would only be 20 -30 litres max
Thanks in advance Brian
Two Strays said
03:41 AM Jun 20, 2012
Bab600
Hello Brian
Diesel is a combustable fuel (Flashpoint above 60 deg C). Petrol is flammable and it has a Flashpoint of around minus 43 deg C. I have one jerrycan for diesel and one for petrol mounted on the "A" frame of the van. The way I see it is that any fuel, regardless of it's flashpoint, furtherest from the rear of the van, the better.
I'm not sure on the legals but I noticed that the van manfacturers at the Brisbane Camping show this month had jerrycan holders on the "A" frame. You would surmise they were abiding by the rules. Well one would hope so.
I use steel jerricans. I have found that the plastic ones for petrol expand too much and have a tendency to rub on the holder, therefore, creating a likelyhood of a leak and or fire.
Point to note, make sure you have identifying markings on the cans that indicate what fuel is in each.
Happy caravanning
Brian
07:58 AM Jun 20, 2012
Two Strays wrote:I'm not sure on the legals but I noticed that the van manfacturers at the Brisbane Camping show this month had jerrycan holders on the "A" frame. You would surmise they were abiding by the rules. Well one would hope so.
They can put jerrycan holders where they like. It is up to you how you use then. It is up to you to determine whether you are going to follow the law or not.
Fuel must be carried within the confines of your vehicles. The front of your tug or the rear of your van are not within the confines of you vehicles. Things mounted on the drawbar are considered within the confines of the vehicle.
Rip and Rosie said
03:35 PM Jun 20, 2012
I wouldn't be carrying any fuel within my vehicle. I had a family member who did that, and died in the fire following a relatively minor car accident.
ozjohn said
04:30 PM Jun 20, 2012
A jerry can of diesel on the drawbar would in most cases be OK , but not on the rear bumper. OJ
bab600 said
06:56 PM Jun 20, 2012
Thanks everyone one problem fixed up
Now to work in fitting the holders
Thanks again
Regards Brian
snapper49 said
10:56 PM Jun 20, 2012
This issue has been discussed at length in many forums I have researched it myself and am yet to see where its says its not legal to carry a container of fuel on the rear of a caravan I know many people do myself included In some cases you can be referred to the dangerous goods act but further reading will show that because of the quantities involved you will find you are exempt
-- Edited by snapper49 on Wednesday 20th of June 2012 11:35:34 PM
ozjohn said
06:23 PM Jun 21, 2012
While it may not be illegal, one must consider the extra weight added well rearward of the axle. Depending on the rear overhang, 20Kg can quickly become 200Kg due to forces applied to the weight as the rear of the van undulates over bumps and through corners etc. This extra weight contributes to Chaotic Yaw forces. Ozjohn
justcruisin01 said
11:19 PM Jun 21, 2012
The big risk of carring petrol on the rear is if some one rear ends you , a fire risk.
JC.
jimricho said
01:35 AM Jun 22, 2012
JC.
One of a number reasons for not carrying jerry cans at all if it can be avoided.
The reason I spent good money to fit a long range tank to my Pajero shortly after I bought it.
snapper49 said
06:01 AM Jun 22, 2012
"The big risk of carring petrol on the rear is if some one rear ends you , a fire risk."
Guess thats why Ive never been rear ended
jimricho said
01:12 PM Jun 22, 2012
Neither have I and never want to be although on one occasion my prostate was checked and that was bad enough!!
Keith19837 said
02:56 AM Jun 23, 2012
bab600 wrote:
What are the legalities of
G'Day Brian. There are some interesting articles by Collyn RIVERS about extra weights at the extreme rear or extreme front of a van (trailer etc). Quite rightly, Collyn speaks of the 'pendulum effect' which can cause excess yaw and/or sway of a van (particularly the longer ones). Collyn remarks on collisions due to the weight vs mass formula when vans have weights (even fairly small weights) positioned at the front or rear. Worth a look by goggling Collyn RIVERS articles. For what it's worth.
snapper49 said
05:50 AM Jun 23, 2012
Funny enough I have just read where somebody had a plastic jerry can puntured by a stone thrown up by the rear wheels of their tug Was bolted on the A frame
food for thought
rtv47 said
03:11 AM Jun 24, 2012
I belive it is illegal to carry Gas at the rear of a vehicle . What would be the diference?
Bab600
Hello Brian
Happy caravanning
Brian
OJ
Thanks again
Regards Brian
Ozjohn
JC.
food for thought
