Anyone own or know of kipor GS 2600 generator. I want to run a Colman roof mounted reverse cycle A/C off it.
Old Crofter said
12:47 AM Apr 4, 2012
load "kipor GS 2600 generator" into the search area above and I think you will find your answer.
Bob
Scotty01 said
01:51 AM Apr 4, 2012
thanks florinhill seems it will do the job and a bit cheaper than the Honda
justcruisin01 said
04:50 AM Apr 4, 2012
Cheaper doesn't mean better.
Scotty01 said
05:13 AM Apr 4, 2012
your rignt JustCruising but also dearer dosnt mean better either
BobnBev said
03:33 PM Apr 4, 2012
Scotty01, Hi They are ok Ive had one for a few years now, and the only problem I had was cracked fuel line.(2 years down the track) It runs the air con. easy and is lite enough to pick up. If you buy a new one RUN it in first or it will burn oil.. I also have the 1000watt. Kipor and its done a lot of hours..... Bob...
DeBe said
05:24 PM Apr 4, 2012
This is an older model Kipor rebadged as Genquip 2600. Had it for about 4yrs now with no problems. Has probably had more hours powering our house during long power outages. As Bob said i ran mine for 10hrs with a 1500Watt load to run the motor in first.
Bob
Bob...
