hi guy's ineed some help with fitting a sterio to my vicount poptopwhat i need to know is what am fm aerial do you guy's use any help would be much appreciated thanks in advance dimgo
10:25 AM Mar 27, 2012
The majority of late model vans I have seen use car radio setups. You just use a standard car aerial with these.
If you are trying to install home type equipment (some people do,) what type of antenna is used in your home situation?
aussietraveller said
06:44 AM Mar 28, 2012
We fitted a car aerial to our last van fairly cheap one from accessories shop and it was still going strong six years later so dont need a special or expensive one to achieve good results.
jimricho said
02:02 PM Mar 28, 2012
That's all I use. Will work on both FM and AM. Suggest mount in such a way that it can be raised (at least partly) clear of the rig if reception is "iffy"
