hi techies, can you advise how long will a 120hr deep cycle battery run a 90ltr waeco 12volt compressor fridge ?? thanks greyghosts,
chris & terry said
04:55 AM Feb 19, 2012
Hi, I have no expertise at all in this area but I am not sure if a single 120ah has enough capacity to run the 90lt effectively. I have an 80lt Waeco & I am just organising 2x 200ah 6v to run mine. If you go to the Century web site they have a table that you can use to calculate usage & a calculation of suggested capacity of power needed.
Terry
Ma said
05:05 AM Feb 19, 2012
Where are you guys at the moment?
BobnBev said
06:02 PM Feb 19, 2012
Hi Greyghost, and others, A 80lt Waeco has a BD50 Danfoss compressor,It will use 5 amps running, And a 120 amph deepcycle Batt. will give you around half the amps of 120 = 60 amphs give or take a few amphs. If its summer it will cycle much quicker, and winter will cycle less, if its used as a freezer or a fridge..... So it hard to say just how it will do on a set battery.... Hope this gives you some insight... Bob n Bev
chris & terry said
08:29 PM Feb 19, 2012
Not sure who you are asking Ma, but if it is us, we are in Perth, or Guilderton to be exact.
terry
justcruisin01 said
08:59 PM Feb 19, 2012
There is no guaranteed time factor here. As stated above is correct, fridge/ freezer/ summer/ winter/ how often you open fridge/ what you add to fridge / state of charge when you stop /etc etc. The power consumpsion of 5amps does not change, its the run time that varies. You will need to recharge on a daily basis.
JC.
greyghosts said
01:56 AM Feb 20, 2012
thanks to all who replied to my querie, gives me some insight as to what i will do. greyghosts
Terry
Bob n Bev
terry
JC.
