Can somebody please tell me how to check if a solar panel is working and/or how much it is producing using a multi meter?
blaze said
09:49 PM Sep 13, 2011
gave you an answer tezza in the main page I think it was, hunt that up or if you cant find it let me know cheers blaze
DeBe said
10:06 PM Sep 13, 2011
Set multi meter to Amps scale & fit in series with the positive lead going to the battery from the solar regulator. It should show some sort of current going into the battery.
BobnBev said
09:52 PM Sep 22, 2011
Good photo Daryl, did you hard wire your MM. for use on the amps . Never thought of that, much easer with plugs like that. Another project for my MM..
DeBe said
08:58 AM Sep 23, 2011
Yes its hard wired as the leads are too light to carry 10A (This meter is not to be used on mains voltage as there would be a risk of shock) It was a $5 multimeter from Cheap as chips, i bought 4 of them at the time & acuracy is comarable to my expensive multimeter.
03_troopy said
12:57 PM Sep 23, 2011
I see the anologue voltmeter has been rescaled too. I used to do that when building test equipment too. We used to get stacks of old meter movements and when we needed one to fit to a project, just replace the shunt resistor with a different sized one then cal it and print up a new face card.
DeBe said
07:16 PM Sep 23, 2011
Got the analogue meter from a scrap yard for free. It was a 250Amp meter from a telephone exchange battery charger. Amazing whats thrown out these days.
10:45 PM Sep 23, 2011
DeBe, did that meter come with its external shunt or is it a type with very heavy terminals on the back?
DeBe said
10:33 AM Sep 24, 2011
Hi Peter, it had an external shunt which unfortunately went to scrap. I wasnt quick enough!
blaze
