hi all. once again a pretty silly question from a newbie. can i, and how do i switch off the 'electric' hot water and use only gas.
blaze said
01:56 PM Sep 8, 2011
does it plug into a power point, If it does unpug it. Most probably hard wired and auto detecting though. Maybe or should be fused, remove fuse. Just some random thoughts in my head cheers blaze
villatranquilla said
02:17 PM Sep 8, 2011
we have a Jayco and there is an electric switch in the corner cupboard bench under the top hatch near the HWS
Andrea said
05:05 PM Sep 8, 2011
Not a silly question, Steve & Maria - I knew how to turn off the power but I've only recently discovered that our Suburban HWS (gas or 240 v) can be used with both at the same time, if you really wish. This was stated quite clearly in the manual that I downloaded (in an attempt to discover why the gas won't stay alight! ).
Keep asking - we all learn that way!
Wombat 280 said
05:49 PM Sep 8, 2011
Mate came all the way from Perth where he picked up his new Jayco Expanda. Followed the instruction book to get the hot water working but no luck, not till he reached Port Macquarie that the Jayco dealer pointed out that there's a power switch under the lounge seat Nothing mentioned in the owners destruction booklet . Obviously didn't listen to the handover takeover brief when he picked it up
Steve and Maria said
08:42 PM Sep 8, 2011
thanks all for your replies; villatranqilla, found the switch. (probably should hav looked there in the first place) thanks again all
jimsiron said
03:32 PM Sep 11, 2011
There is also a switch on the unit itself when you open the access hatch. Ours is near the bottom LHS part hidden behind some piping on our Discovery . We were shown this on pickup in June by the selling dealer in the predelivery as the way to turn off the mains power supply.
regards
jimsiron
aussietraveller said
07:56 PM Oct 3, 2011
On the 2005 jayco heritage there is a toggle switch in the hot water hatch as jimsiron said, I have always made a point of turning this switch off on return home and I usually drain the tank but last time I forgot to drain tank and this morning I decided to replace the anode prior to our trip starting next week and the pressure in the tank was still very high and the amount of muck that came out of the tank 'and all over me' was unbelievable so suggest when changing anode give tank a very solid flush out.
blaze
regards
jimsiron
