I have a friend who has static interference in his caravan radio when the LED bed reading lights are turned on, this has only just started as the lights have been in for a couple of years it has him mystified.
Has any one previously experienced this and what was you rectification method.
Regards Jim
chris & terry said
09:22 AM Aug 6, 2011
Hi Jim, yes static interference from LED lighting can have an effect radio performance, but the pros of LED lights far outway the cons. If it is too big a problem suggest they get a small hand size transister, cost around $20. Good value, good reception, good easy to handle size, & good battey life.
Terry
Hi Jim ..
Its probably of no benefit to you, but I operate a HF Radio as I travel. About 18 months ago I replaced most of my (internal) Halogen lights with LED's so that I might benefit from the low power consumption ..
However, when I transmit on the radio now, the LED's (not switched on) will light up like Christmas trees ..
If he's getting interference from the LED's, then I can only think it may be an older style radio that may be more susceptible to interference .. or .. ask him to just check the switching arrangement for the LED light. It may not be seating properly where inserted or when switched on .. a LED can still light up because it can 'arc' across a dirty connection .. and 'arcing' can certainly cause interference.
Try cleaning the connection .. ensure the LED is firmly seated and failing this, ask him to try another LED in its place ..
about all I can suggest Jim ..
Jon
Nichol said
09:35 AM Aug 6, 2011
Hi,
Led lights have a power adaptor built into them to take the 12 volts and convert it to the correct power to light the led.
Depending on the quality of these internal adaptors it is possible for them to generate electrical noise that interferes with radios that are not isolated from this noise.
Like has already been suggested good quality LED replacements are usally but not always ok, and usually cheaper than trying different radios.
Nichol
11:06 PM Aug 6, 2011
If nothing else has changed, this often indicates some sort of failure taking place in the lamp or lamps. Is it all the lamps or just one of them causing the problem?
jimricho said
07:51 AM Aug 7, 2011
I'm not familiar with the internal workings of these super-bright led fittings but maybe some of them use some form of switch-mode type voltage/current regulation that can generate RF interference? Their wide input voltage range (8 - 30 volts) alludes to this possibilty.
I recently installed a 30 led outside (weatherprof) strip light that does not cause any radio interference.
I had an interference problem with some 12v fluoro fittings that I overcame by installing a filter in the light fitting.
patrolst said
09:12 AM Aug 7, 2011
Hi Terry
Thanks For your advice, I think he wants to keep the radio as the interference has only just started.
But I will forward your suggestion.
Regards Jim
patrolst said
09:15 AM Aug 7, 2011
Hi Jonathan.
The radio is about 3 years old and the lights have been in for a couple of years.
I will forward your advice on checking the cleaning of the switching.
Regards Jim
patrolst said
09:18 AM Aug 7, 2011
Hi Nichol.
The led's are good quality as the were installed when he had the solar installed.
Regards Jim
patrolst said
09:20 AM Aug 7, 2011
Hi PeterD
The lamps aren't very old and it is happening in both off them.
Regards Jim
patrolst said
09:25 AM Aug 7, 2011
Hi Jim
I'm not sure if a filter can be installed on the led's as can be on a fluoro, it has been suggested that he install ferrits on the wiring to the lights.
Regards Jim
Terry
Hi Jim ..
Jon
Hi,
Nichol
Hi Terry
Regards Jim
Hi Jonathan.
Regards Jim
Hi Nichol.
Regards Jim
Hi PeterD
Regards Jim
Hi Jim
Regards Jim
