I am about to instal 2x120w solar panels and have read on this forum that you should use 6 gauge wire (also called 6 B&S) as against 6 mm. Can someone tell me the difference and what does b&s stand for. Also, how can I tell what cable it is?
Thanks in advance
Patto.
ozjohn said
04:08 PM Jul 27, 2011
6 B&S is 13.5mm(Sq) cable. The B&S stands for Brown & Sharpe who were an American Engineering Company. Their wire sizes became the standard for AWG (Amerigan Wire Guage). Cheers, OJ
Patto44 said
04:18 PM Jul 27, 2011
Thanks OJ. Now it makes more sense. 13.5mm is obviously a lot more suitable. The guy that gave me a quote assured me that 6mm auto cable was ample as the panels only have 4mm cable coming out of them. If he does not want use 6 B&S he won't get the job. Cheers, Patto
ozjohn said
07:38 PM Jul 27, 2011
Mate, I only answered the question of what 6 B&S cable is, not what should be used on solar panels. 6 mm auto cable or even smaller may be OK as the amperage from Solar Panels is pretty low.
But like you, I think it's best to wait for a reply from a qualfied member who knows what they're talking about.
-- Edited by ozjohn on Wednesday 27th of July 2011 07:42:29 PM
-- Edited by ozjohn on Wednesday 27th of July 2011 07:44:51 PM
-- Edited by ozjohn on Wednesday 27th of July 2011 07:45:38 PM
bill12 said
07:55 PM Jul 27, 2011
Bigger is better, as there is less resistance in bigger copper cable. Use the biggest copper cable you can afford.
blaze said
08:42 PM Jul 27, 2011
Also dont think that thicker copper strands is better either, finer strands and more is better. Less loss over distance. cheers blaze
landy said
09:43 PM Jul 27, 2011
Try doing a search for a site called hobohome, there is a heap of info there on wire size for solar panels, as well as a lot of other usefull info. Well worth a read.
Voltage drop = (cable length (in metres) X current (in amps) X 0.017) divided by cable cross-section in mm.sq.
You can safely have a 1 V voltage drop in the cables fom your panels to your regulator. Your panels will put out a maximum current of around 14 A. Let us assume that your cable length is 10 metres (and you double this as you are not using an earth return,)
We can transpose the formula to get:
Cable size = (cable length (in metres) X current (in amps) X 0.017) divided by 1
Therefore Cable size = 20 x 14 x 0.017 = 4.76 squ mm.
This equates to the size of coper in a 6 mm auto cable (the ones I have actually have 4.8 squ mm of coper in them.) There is no standard for the amount of copper in auto cables. If you read through the article I gave the link for, you will see the actual amount of cable the authour measured in several samples of 4 mm auto cable. All Australian standards quote sizes in square milimetres of copper. The auto and solar industries tend to use American sizes of cable.
-- Edited by PeterD on Thursday 28th of July 2011 12:37:54 AM
jimricho said
07:41 AM Jul 28, 2011
I'm no "expert" on solar installations but I would be inclined to think that the "6mm" twin cable available from a marine supplier such as Bias or Whitworths would be fine for the job. The marine type cable is tinned and less prone to corrosion due to exposure to the elements over time.
That would be my choice of cable. I would pump for 6 squ mm cable as it goes one stage bigger in size than what I calculated. Also as jim said, tinned copper cable is better for exposed locations. If you do happen to get moisture in, the wire will not get verdigree and rot out.
Patto44 said
05:11 PM Jul 28, 2011
Thanks for all the info. I am still sifting through the links etc. and trying to make the right decision. Hobohome is an informative site. Been advised that to instal with 6 B&S is only an extra $80. so will go with that just to make sure.
Thanks in advance
Patto.
Cheers, OJ
Patto
Mate,
Cheers, Ozjohn.
PS> have a search on this site for solar info. www.caravanandmotorhomebooks.com/books/index.htm Then look in 'Articles'
blaze
Landy
From this site we get the formula:
http://www.hobohome.com
Link for hobohome site. Lots of info
Patto
