Generators! I guess that this is a topic that everyone has an opinion on.
Our little Jayco Starcraft Poptop van is the last(?) of the 240v systems with 2x12volt lights added to the 240v ones.
We do like to bush camp and we use a deep cycle battery to run the lights, and gas for cooking in the van and fires for outside cooking. The battery is free standing outside or under the van, wherever there is space. There is no boot in the van.
Unfortunately the battery need charging every now and then, and I have a Honda Gennie to accomplish that.
We ont have a problem of being without the TV, but we do need to get on the net to check emails etc, reasonably frequently.
I looked under the bonnet of the tug and found enough room to put a matchbox.
I looked at Solar Panels and all the required bits and pieces to go with them and SHMBO had to revive me with strong stimulants.
Is there anything that I can do to reduce the need for a Gennie?
Or would it be simpler to fire it up every now and then?
Any clues and ideas would be greatly appreciated.
Please keep it simple and easy. (oops just described myself then.)
Thanks
Brownie
05:16 PM Jun 21, 2011
I don't have any answers but just a few questions Brownie. Where do you store the genny?, they take up a lot of room. They are quite heavy aren't they? so how do you get on lifting it when needed? Wouldn't a solar system be better on the roof as it is lightweight and stays in one place and although costs a bit will do the job a lot quieter and always be there? Thinking for myself as well as you with your dilemma.
jimricho said
06:42 PM Jun 21, 2011
Re the Computer (assuming it's a laptop).....
The best option is to purchase a 12v power supply. This connects to the laptop instead of the normal 240v power supply and cord and will recharge the laptop in the same way.
I intend getting a 12 v ciggie lighter connection for my laptop. Will take away one worry, can recharge while travelling. I asked in Dick Smith the other day, the woman couldn't show me anything. I asked if there was a connection with varying attachments. Never heard of it she said. Maybe she was new on the job.
07:15 PM Jun 21, 2011
Need to find a Jaycar Marj - bit more specialised than the other -
DeBe said
07:59 PM Jun 21, 2011
I have Solar But i also use a Generator. If you only want to charge batterys ocasionaly use a small generator & battery charger. There are plenty of 1000Watt generators which are relativly quiet & small. Brand of generator depends mainly on howmutch you want to spend.
jimricho said
08:30 PM Jun 21, 2011
Dick Smith is just an electronic toy shop these days. jaycar list a stockist in Echuca... "Switched on Electronics" They also list a branch in Shepparton at Shop 4 575 Wyndham Street.
Click on that link in my earlier post in this thread for more info.
Your existing arrangement may work out for you once you get your house battery issues sorted.
Sheba said
08:59 PM Jun 21, 2011
This is a link to show you the one I have. I will be using it direct from the Solar Battery.
-- Edited by Sheba on Wednesday 22nd of June 2011 12:59:22 AM
Wombat 280 said
09:19 PM Jun 21, 2011
Not knowing your computer type or needs but it is possible on a lot of laptops to up size the battery to one with a higher capacity. Normally the one that comes with a LP is only small capacity unless you ask for the more powerful unit . It will give you a lot longer before recharge is needed . A genie doesn't take long to top up the batteries basically a lunch time stop will do it .
ChiChi1 said
09:35 PM Jun 21, 2011
I also have thought about this question. To have or not to have a generator.
Peterpan, seeing you have one I would definitly keep it and use it.
I decided not to get one because, (1) They are expensive, and I figured I could have a lot of nights in a CP for the price. (2) They are heavy and I could'nt lift it. (3) I have no space to carry it anyway.
My solar set up is definitely not large enough even to run fridge and lights only. Will be looking at getting a larger setup. (just don't know where to start at the moment)
Son got me some special plugs so that I can plug into the 12v system for the laptop. (he still has to fit them) He said they did'nt cost much. Will ask him what they are and how much. In the meantime intend to charge up as I go along. (he's an IT techie)
-- Edited by ChiChi1 on Tuesday 21st of June 2011 09:36:46 PM
Sheba said
10:11 PM Jun 21, 2011
These
These.are the plugs I use . The first one is attatched to the Battery. The second plugs into it, and I could use 3 items at a time if necessary. I think you can get 5 plug adapters now. They are not at all expensive. I think the Triple was under $10.00
The one that link takes you to is a 240 V device, not 12 V.
I have rectified that Peter. Thank you. I hadn't noticed it was the wrong one.
The above Link is the correct one now.
-- Edited by Sheba on Wednesday 22nd of June 2011 01:06:05 AM
bill12 said
04:51 AM Jun 22, 2011
I run my toshiba laptop from 12v with a multi voltage cig lighter attachment, which runs off the house battery, with is charged by 120ws of solar .It also runs the fridge /freezer, along with the tv, and other stuff. I have a dongle so you can get digital tv on you laptop, but usually use the separate tv/dvd combo. All batteries are charged with the engine alternater when running. I have a genny, but don,t use it very much, usually for power tools or emegencies.If you need help on how to set things up, please ask or pm.My system seems to work well as I can usually go a week til I have to start the car engine.I hope this helps. Bill
jimricho said
08:39 AM Jun 22, 2011
That's a pity that the Dick Smith person wasn't more helpful or at least didn't get another sales person who was more knwledgeable to attend to your enquiry.
Without knowing the specifics of your laptop I think that the Dick Smith one as suggested by Sheba would be fine for the job.
Maybe Bill12 could provide you with more specific details of his unit as he seems to find it ok. (sorry to dob you in Bill )
Jim
lost Gypsy said
09:14 AM Jun 22, 2011
wouldnt an inverter solve this problem, I bought a small one for $75 from and I can use it off the car battery for a few things.
10:08 AM Jun 22, 2011
Like your photos Sheba. Will go looking for something similiar. I do have an inverter lost Gypsy and when I get a new inhouse battery it will work. But thought I would get the other as a back up as well.
Bent Axle Bob said
10:50 AM Jun 22, 2011
My rig is set up with a 120 watt solar system mounted on the roof of the box body charging a 105 amp hour deep cycle AGM battery. This runs my fridge, cooler box, lighting etc with no problems. All lighting (lots) is LED 12v, although the trailer runs 240v led lighting. I run 2 small invertors, one on the truck and another in the camper trailer. Using the invertors allows me to charge my phone, net book,TV etc. The trailer is electrically connected to the truck via heavy anderson plug cables and both systems are fuse protected. When the engine is running , the alternator also charges the deep cycle battery. As the sun doesn't always shine, I also have a small 1KVA generator. As a note, those cigarette lighter outlets are best left alone, They are cheap..but they are nasty and tend to over heat and also have been known to start fires
Peterpan said
05:38 PM Jun 22, 2011
G'Day All, WOW, what a fantastic amount of information. Thanks a lot. To answer a couple of your comments,
Happy Wanderer, We store the Gennie in the Van, under the table between the leg and the seat. It has to be on my side as my legs are shorter. Its not too heavy to move around.
Jimricho, We have a 12v supply for the laptops which enables them to be charged while driving. I think that while charging the battery from the gennie I can run the 240v system in the van and charge the laptops then. I think an hour would probably do.
Sheba, we have the sme type of plug, but they get pretty hot when everything is plugged in.
Chichi, I am in agreement with you,I reckon we'll stick with the gennie and look at getting a fold up solar panel. Storeage space in the tug and van is a problem but can be overcome.
Thanks for your help
Brownie
jimricho said
06:01 PM Jun 22, 2011
Provided it's a pure sine wave (PSW) inverter. A $75 inverter would not be pure sine wave. These cheaper inverters are (erroneously) called "modified" sine wave (MSW).
Using a MSW inverter with sensitive electronic equipment runs the risk of it not working properly or even damaging it. There are probably many out there who have used a MSW inverter with a laptop without problems but given the cost of laptops and the inconvenience of having one fail I would not consider it a risk worth taking.
Pure Sine wave inverters usually cost 2 - 3 times that of MSW but I recall Super Cheap Auto having a 300 watt (I think) one for around $120 which is very good price.
I think this what "Happywanderer" uses, Marj (HW) may be able to confirm this.
For those who wish to use an inverter for other purposes as well, a Pure Sine Wave inverter may be a viable alternative.
(Note: this post has been edited to correct a significant technical error in the original)
-- Edited by jimricho on Wednesday 22nd of June 2011 06:32:17 PM
milo said
06:12 PM Jun 22, 2011
for laptops while on the road you could try something like this
Sheba wrote:(pictures deleted by jimricho to save space...refer to original post)
These connectors are ok for items that do not draw much current such as phone chargers, ipods, gps etc. Inverters can draw quite a bit of current when they have stuff plugged in to them (depending on the size of the inverter and what's connected). Too much current being drawn through a setup like this can overheat the plugs and sockets and damage them. (note the comment to this effect in Peterpan's post above)
It's also been my experience that they are not reliable enough to run car fridges although some people may have used them without problems.
My preference is for the Clipsal 2 pin plugs and sockets that look like ordinary household 3 pin plugs except for the pin configuration. This would also be my preference for a smaller inverter. Larger inverters should be either "hard wired" to the battery or connected via an "Anderson" type plug.
-- Edited by jimricho on Wednesday 22nd of June 2011 06:37:26 PM
jimricho said
06:24 PM Jun 22, 2011
Possibly an alternative when away from both mains/genny power and 12 volt power. A bit more costly though. I hadn't come across them before so I don't know enough about them to pass comment beyond this.
jimricho said
06:29 PM Jun 22, 2011
One comment about charging 12 volt batteries from a genny is that the 12v output on the genny may not adequately charge a battery and that the better option is to use the normal 240v output via a normal battery charger. I don't have hands-on experience with gennies so someone with a technical background who has, may care to comment further on this.
Sheba said
06:52 PM Jun 22, 2011
So are my Plugs OK for Lap-tops Jim ?
jimricho said
07:10 PM Jun 22, 2011
I would think it would be ok but I'd be inclined to plug it directly into a socket rather than through that adaptor if that's practical. Try it in the adaptor but feel the plug to see if it gets warm. If so you may have to use a separate socket elsewhere in the vehicle. I definitely wouldn't run an inverter or car fridge through that adaptor.
cheers,
Jim
(PS: This advice will cost you a lemonade scone! )
-- Edited by jimricho on Wednesday 22nd of June 2011 07:13:44 PM
Sheba said
07:27 PM Jun 22, 2011
Geeze!!! I haven't done any real cooking for at least 15 years. You might be better making your own. I know you have the Recipe.
G'Day All,
Thanks
Brownie
Click on this link... http://www.jaycar.com.au/productResults.asp?keywords=car+laptop+power+supply&keyform=KEYWORD&SUBMIT.x=15&SUBMIT.y=4
http://dicksmith.com.au/product/M9694/90w-auto-air-adaptor
Jim
Brownie
http://www.ht.com.au/part/Y5095-Energizer-Energi-To-Go-XP18000-external-battery-pack-Li-pol/detail.hts
cheers,
Jim
