Whilst in Mildura recently..I found a nasty leak under my awning and coming inside Had to get the tarp out it was that bad.After close inspection will have too do some paint stripping and cleaning in and around gap....Any suggestions on something to plug hole and then Fibregallss it
Peter_n_Margaret said
06:40 PM May 25, 2011
What is the "hole" made from?
Cheers, Peter
gubby said
06:43 PM May 25, 2011
If you're going to fibreglass it that will seal it, all you need is something to stop the fibreglass until it sets, even just a bit of flywire rolled up and pushed into the hole.
jimbo said
07:43 AM May 26, 2011
Peter n Margaret Gubby...Rusted away I figured....Guess I'll put some bog in it smooth it out anf then Figregalss it...I'm only talking about a 5 cm I have only just started to clean around the area
gubby said
08:25 AM May 26, 2011
Try to make sure that you either cut out all the rust or treat it otherwise in the not too distant future you'll be doing it again...
