I'm still working on getting my van for my travels.
I will be travelling solo so don't need a large van. My budget isn't large so I am looking into vans built in the 80's or early 90's & up to about $10k preferably.
My vehicle tow limit is 1600kg with a 160kg towball limit so I need to stick to something around the 15ft max.
I would like a van with an aluminium frame if possible to minimise any problems associated with timber getting wet & rotting.
Who apart from Viscount made vans in the under 15ft range & with an aluminium frame?
All suggestions are welcome.
Cheers ......... Alan
BobnBev said
03:41 PM Apr 25, 2011
Hi They are not a totaly Ally framwork. its a deep C section of ally on the out side with a timber inersection on the in side . they seem strong , I walk on my roof and there seems no problem.. easy to tell just look for riverts on the out side of the van.. hope this helps...
04:07 PM Apr 25, 2011
My 4.3m (14ft) Coromal has a weight of 850kg.
10:42 PM Apr 26, 2011
Leaking vans rot more than the framework. It is more important to get a van that does not leak rather than going hell bent to get an aluminium frame. It's no good having a perfect frame if the timber lining and cupboards are rotting out.
D-evil-ace said
08:16 PM Apr 30, 2011
Thanks for all the input. I'm in no hurry so will keep checking my options. Alan
Alan
