hi all i hope every one is fine and going good, just wondering if some one can tell me what temp to set my fridge on as i wont to turn it into a freezer. i will have my 40lt waeco as my fridge and set the 35lt as my freezer that way we can travell a lot long without stopping at shops any input would be app regards possum,yvonne
bill12 said
04:02 PM Nov 20, 2010
I set my 55ltr at -2c and it keep my fish frozen, and beer cold in the ther compartment.Have a 2 battery system with a marine manuak rotary switch as they use no power, and it seems to work fine.I can go 4 to5 days and still start the diesel.I hope this helps.
possumyvonne said
04:57 PM Nov 20, 2010
hi bill, thanks for your reply would -2 be enough if i restock it with meat and vegs and other things as i thought it might have to be lower to freeze it quicker so it doesnt go off what do you think regards possum,yvonne
DeBe said
07:53 PM Nov 20, 2010
Hi Possum. I run mine @ -10 to -12 deg C as a freezer mutch safer temp for food storage, ideal is -14 to -16 deg C but i find a bit heavy on power consumption on that setting. Daryl
possumyvonne said
08:01 PM Nov 20, 2010
hi daryl, hows things, its been awhile since we chatted how long do you think the both of them{fridge,freezer} on 103amp agm batt fridge on 3 and freezer on -13 thanks for your input regards possum
possumyvonne said
08:40 PM Nov 20, 2010
hi daryl, hope you can give me some advise on something here goes i have got my 103amp agm batt, 35,40lt waecos,dual batt system 850 generator, and 800watt inverter, eva-power power supply/battery charger 240vlt question is, what would be the best way to use all these things to make our travelling as efficient as possible. how would you hook it all up if you were doing it hope you dont mind me asking regards possum
DeBe said
11:00 PM Nov 20, 2010
You will probably get 2 days outof the battery depending very mutch on the temp of the day. using the unit asa freezer you will probably use double the Ah rating compared to fridge temp. For battery charging get as mutch as you can out of vehicle altenator generaly if im traveling a fairbit during the day its enough. But if im hanging around mutch use a genny & battery charger. I do have a 100W solar panel this only just keeps up with a 80L waeco upright fridge, if not enough sun its back to generators. Daryl
possumyvonne said
12:03 AM Nov 21, 2010
thanks for the info daryl, talk soon regards possum
BobnBev said
08:38 AM Nov 21, 2010
Bill12, is on the ball Possum, You dont need to freez the ar...s of your stuff if its only for a few days ..weeks..-2 to -4 is plenty for that time. IF you were going to keep it any longer yep go for a lower temp...All you will be doing is useing power for nothing..What we do is run it a little harder in the day when sola power is at its best, then you can turn the fridge down over night , or off ,to save power..Just remember to turn it back on next day...Big smile..
bill12 said
11:55 AM Nov 21, 2010
Its seems to work. I have just come back from NT, barra fishing, and it kept the fish frozen all the way back to Magnetic is, The only problem was there was no room for the beer!I had to give away barra fillets to fix a 6 back in. You have to get your priorities right.I have a deep cycle150amp hr, and a 120amp/hr starting battery, and 3 -40 w solar pannels on the roof.
possumyvonne said
08:14 PM Nov 21, 2010
thanks every one for your help and ive learnt a lot, its great to see that even if our problems are small theres poeple out there to help and sort it all out again all the ways that every one uses there fridges and freezers comes back to experience, also thanks to thoughs how also helped with my battery issue, that also helped regards possum,yvonne
Peter_n_Margaret said
05:34 AM Nov 22, 2010
The colder you run your freezer the more power it will use.
The more often you open it, the more power it will use.
The warmer things are when you put them in, the more power it will use.
The hotter it is where your freezer is kept, the more power it will use.
Same for the fridge.
possumyvonne said
08:58 PM Nov 22, 2010
thanks for the input peter and marg, yeah, ive been doing a triall run at home and seems i can get about 38hrs before charging, so i think i will keep my eyes open for some cheap but good solar panels regards possum, yvonne
BobnBev said
07:13 AM Nov 23, 2010
Possum ,Cheap is not allways best.. But better than none...Good luck with it ......
possumyvonne said
02:22 PM Nov 23, 2010
hi bobnbev, sorry about that, i dont mean cheap, as in crap, i mean cheap as in good but cheap regards possum,yvonne
what do you think
regards possum
here goes
i have got my
regards possum
regards possum
