i see the small portable loo's at the camping shops nowdays are they ok for over nite use when cold or wet? can you use these at dump points ?
brickies said
07:32 AM Aug 28, 2010
Sure can MILO
clazandaza said
04:39 PM Aug 28, 2010
We have relied on "Barry the Bucket' for a number of years now. Ok for number ones of course.
' Barry' is almost a member of the family.
05:06 PM Aug 28, 2010
The good ones seem to be about 100.00 at camping shops. They have a cassette thingy that is closed off, you must just take that cassette out and go empty it. I wondered how too as I thought dump points had a hose thingee to attach the van too for normal toilets. Are they easy to empty and rinse?
I intend getting one too and having a cushion top seat made for it so it just looks like an extra seat.
-- Edited by Happywanderer on Saturday 28th of August 2010 05:07:45 PM
elliemike said
07:33 PM Aug 28, 2010
Yes they are easy to rinse. They can be a bit heavy though. Ellie ca'nt manage the dumping bit these days. Although I dont have a problem with the weight of the cassette
Hav'nt got one at present, will be buying another in the near future. The New Avan Cruise liner has room for carrying it.
But Please- Please, dont rinse them with the water taps that people use for drinking water.
There are (should be) rinse taps at the designated "Dump Points"
I submitted a post about this disgusting practice earlier this year.
I have seen two instances in the last eighteen months, of people rinsing them out with the drinking water taps in their C/P camping bay. Tap inside the dump spout. Grrrrrrrrrrrrrrr. And yes I did go Grrrrrrrr Grrrrrrrr to both people.
Some people just dont think !!!!!
Regards Mick and Ellie
coyotte said
08:59 PM Aug 28, 2010
If your worried about the weight --- they come in two sizes --- 10 ltr & 20 ltr have had a 10 ltr for ages --- their great if away from ammenites --- just use a bottle and the porta-loo when needed.
Coyotte
brickies said
09:34 PM Aug 28, 2010
If you are worried about the weight empty more often don't wait till it is full, new dump sites have a good set up open the large lid empty the content and they have a short hose for you to flush the the cassette into the pit , we use nappy san in our porta potti
Aboutime said
11:12 PM Aug 28, 2010
Hi, we had a porta potti that came with the second hand caravan we bought but it didn't fit under the bed when put together. So once we had used it - we had to keep it on the floor of the caravan till we stopped then put it outside till we moved off again.
We have now bought a smaller one that will fit in the storage area under the bed when 'together'. The porta potti has been great for freedom camping when there is no toilet available (or they are so bad you really don't want to use them). We bought one of those pop up ensuite tents too. Emptying the porta potti is easy as 'brickies' has mentioned.
Make sure the one you buy fits the storage space available. Cheers
Beth54 said
08:51 PM Aug 29, 2010
In outback Qld I found that not all dump sites have the lid and tap/hose. A couple only had a pipe into the ground, which was a bit tricky.
Mine is a 20lt but I only fill it half way as it'd be too heavy for me. I wouldn't be without it these days.
brickies said
09:29 PM Aug 29, 2010
Remember the cassette tank of a Porta potti is still smaller than the tank of the toilet of a en suite toilet in caravan or motorhome. we all know our limits and empty at a level that we can handle
01:25 PM Aug 30, 2010
Thanks for all your great advice, some things there I didn't know before.
The portaloo I looked at in our local camping shop looked quite small in the cassette area, in other words didn't think it would be that heavy, will go have another look.
Travel Bug said
09:22 PM Aug 30, 2010
Thanks everyone for your very helpful advice.
I sure picked up a few tips that I hadn't thought of.
GrumpyOne said
10:18 PM Aug 30, 2010
REMEMBER
1 litre of liquid/slurry equals approximately 1 kilogram in weight.
10l = 10kg plus the cassette
20l = 20kg plus the cassette.
Dunmowin said
09:20 PM Aug 31, 2010
We have a Dometic 976 for sale if anyone interested and in / around / passing through Brisbane. Only 12 months old, only used on two weekend trips (long, long story)
With caravan (& ensuite) on order, won't be needing it again. $100.00
"Dometic 970 series: Small but a big performer, handy space-saving, the new 970 series adds hygienic comfort to your boat, motorhome or campsite. Many sensible functions are included such as; push button control for powerful flushing and less pumping; safety through overfill protection and tank level indicator; ingenious disposable system with extra-long pivoting spout and vent openings for clean, spash free discharge. This 976 model has a 18.9 ltr holding tank and a 18.1 ltr fresh water tank. Dimensions 387 x 333 x 387mm. Weight 5.9kg"
Mick and Ellie
Coyotte
