We have a 150ltr Dometic Tropicalised 3 way fridge. In up to 33 degree ambient temperatures, on gas or 240 volts, the fridge goes as low as -4 degrees. This occours on settings of 4 and above. We are currently in Karrartha WA. Anyone else had this problem? The fridge is defrosted regularly.
jandas fun said
03:13 PM Jun 25, 2010
Hi Noel,
according to my info, the temp of the fridge should be between 0c and-5c and the freezer up to -18c. depending on ambient temp. (and whats in it/how often is it opened etc) Your figure is what my fridge works on.
Happy travels.
Johnw
jimricho said
05:13 PM Jun 25, 2010
Just turn the thermostat control back a bit mate, that's what it's there for. Try 2 instead of 4 and see what happens.
Paul-NSW said
07:25 AM Jun 26, 2010
We have the same fridge. Thermostat is not on 2. Can only see top half of the 2. Fridge is 2.4C
Why didn't you turn down the thermostat if the temperature was to low?
Look to the fins on the LH side and ensure they are not iced up. Defrost if necessary.
Wombat said
10:12 AM Jun 26, 2010
Thanks for answers. I've had it set as low as 2 and it will still freeze up at times. I'll put down to being made on a Wednesday.
jimricho said
04:14 PM Jun 26, 2010
Wind it back till it doesn't freeze but make sure that the lowest setting doesn't turn it off completely. Also check thet the freezer section is still cold enough and stuff doesn't start to thaw
-- Edited by jimricho on Saturday 26th of June 2010 04:15:35 PM
DeBe said
07:06 PM Jun 26, 2010
hI Wombat, Mechanical thermostats are not acurate devices & the numbers dont realy mean any thing. For example I have a Waeco CR80 fridge in my van & the thermostat setting is 7 to get it to run @ 3Deg C, where others find setting 2 is ok.
Delta18 said
11:46 AM Jun 27, 2010
jandas fun wrote:
Hi Noel, according to my info, the temp of the fridge should be between 0c and-5c and the freezer up to -18c. depending on ambient temp. (and whats in it/how often is it opened etc) Your figure is what my fridge works on. Happy travels.
Johnw
This would be ok if you like frozen lettuce & tomatos etc.
The fridge cabinet should be between 0c and +5c. Never above 5c.
I find that if I have mine set to 0c in the morning (about #3.5) then later in the day allowing for openning a few times it will only rise to 4c - 5c. without further adjustments.
-- Edited by Delta18 on Sunday 27th of June 2010 11:47:49 AM
gold dandelion said
12:19 PM Jun 27, 2010
if you leave the door open to long or to frequent wont help, this causes fridges and coolrooms to freeze up, or if air is getting in some where.
Bradbury said
03:44 PM Jun 27, 2010
Hey Wombat we are in Karratha at the moment and our fridge is o.k.Drop us a line if you would like to catch up Syd & Donna
jandas fun said
07:50 PM Jun 27, 2010
Delta18 wrote:
Johnw
Whoops. getting my - and + mixed up. Delta18 has it the right way around 0 to +5c in the cabinet. is the recommended temp. Actually, i do try to get the temp. down to minus or less in the cabinet when free camping, as i don't use 12v when i travel and the fridge stays cold til i can get the gas back on, later in the day.
Johnw
Cupie said
08:09 PM Jun 27, 2010
G'day ..
Good to see that you don't have the usual problem of the fridge not getting cold enough.
I use an indoor/outdoor thermometer to constantly monitor the temp & adjust thermostat accordingly.
To fix the freezing lettuce & tomatoes ... Put them into plastic containers with a bit of kitchen paper. Works for me.
I prefer tomatoes out of the fridge to ripen fully. Bit hard in the really hot though.
Of course I could loan you my family who constantly open the door then pause to think about what they want to get out of it. Eventually remember to close the door. No over cooling in my van fridge.
Fridge is 2.4C
Syd & Donna
Johnw
(ps. The grog is in the engel .. no problems!)
