P = The problem logged by the pilot.S = The solution logged by the mechanic.
P: Left inside main tire almost needs replacement.S: Almost replaced left inside main tire.P: Test flight OK, except auto-land very rough.S: Auto-land not installed on this aircraft.P: No. 2 propeller seeping prop fluid.S: No. 2 propeller seepage normal. Nos. 1, 3 and 4 propellers lack normal seepage.P: Something loose in ****pit.S: Something tightened in ****pit.P: Dead bugs on windshield.S: Live bugs on backorder.P: Autopilot in "altitude-hold" mode produces a 200-fpm descent.S: Cannot reproduce problem on ground.P: Evidence of leak on right main landing gear.S: Evidence removed.P: DME volume unbelievably loud.S: DME volume set to more believable level.P: Friction locks cause throttle levers to stick.S: That's what they're there for!P: Transponder inoperative.S: Transponder always inoperative in OFF mode.P: The T/C ball seemed stuck in the middle during my last turn.S: Congratulations! You've just made your first coordinated turn.P: Suspected crack in windscreen.S: Suspect you're right.P: Number 3 engine missing.S: Engine found on right wing after brief search.P: Aircraft handles funny.S: Aircraft warned to straighten up, fly right, and be serious.P: Radar hums.S: Reprogrammed radar with words.P: Mouse in ****pit.S: Cat installed.P: Radio switches stickS: Peanut butter no longer served to flight crewP: Screaming sound in cabin at start-upS: Company accountant deplanedP: Funny smell in ****pitS: Pilot told to change cologneP: Aircraft 2,400 lbs over max weightS: Aircraft put on diet of 92 octaneP: #3 engine knocks at idleS: #3 engine let in for a few beersP: #3 engine runs like it's sickS: #3 engine diagnosed with hangoverP: Brakes howl on applicationS: Don't step on 'em so hard!P: Radio sounds like a squealing pigS: Removed pig from radio. BBQ behind hangar tomorrowP: Whole aircraft smells like BBQS: Ground Checks OKP: First class cabin floor has a squeakS: Co-pilot told not to play with toddler toys in cabin anymoreP: Electrical governor is brokeS: Paid off governor's debt to Jimmy "The Fish" Galvano
P: Radar hums.
S: Cat installed.
S: Ground Checks OK
