Hi again; have 2008 Jayco Sterling with Sphere tv; says tv is digital, but reception not good in most places. Have a set top box but don't know how to fit it. Can anyone help? Thanks, Colleen
dave06 said
01:44 PM Oct 7, 2009
hey Colleen, just before I explain just check on your instructions to see if you have "an inbuilt" set top box, if you have then disregard the following, if not then follow these
at the rear of your tv can you see 3 different colored knobby inputs, these are your RGB inputs, they should be yellow red and white
on the rear of your set top box you should have three matching color coded outputs (red yellow white) labeled "tv" or "output" or something similar
you need a set of "rgb" cables, red, yellow and white, run these from the output of the set top box to the input of the rear of the tv
now this is not the end of it, you still need an antennae, internal or external, run the coax (black wire) from the arial to the rear of the set top box, it will have a connection labeled "input" or "antenae" it will only fit in the "female" recepticle anyway
plug the unit in and switch it on and tune the antennae and you should have a working system, you will find that digital is harder to get than analogue (old tv reception) and you may not get tv at all in a lot of places
but I hope I have helped you just a little
-- Edited by dave06 on Wednesday 7th of October 2009 12:46:36 PM
RobCol said
04:31 PM Oct 7, 2009
Thanks Dave but the tv doesnt have the red yellow white input bits!!!! Will be interesting to see if I get advice from fellow Jayco owners, have also posted a query on Jayco forum Cheers, Colleen
dave06 said
05:15 PM Oct 7, 2009
O.K. does your set top box have coax in as well as coax out (two large silver outlets), if so run coax (the black cable from your arial) from the s/box to the telly as with the rgb ( tri color cables) cables
Basil Faulty said
08:04 PM Oct 7, 2009
Dave sorry to be a pedant but you mean RCA inputs, out puts and lead, red yellow and white.
dave06 said
08:09 PM Oct 7, 2009
quite happy to be corrected Basil, not my field I'm afraid,
Thanks,
Colleen
Cheers, Colleen
