6B&S from the car battery to the van battery. And it's not just "my belief".
I've just pulled the van's trailer plug apart to see what wiring there is. Sure enough, P2 has an 8B&S. P2 on the Jeep has a lighweight cable which runs through to the rear cargo power outlet (that's switched on and off with the car's "ignition". When I bought the van I was told that the owner installed a second battery so it would run the fridge from the van battery. Obviously this is incorrect.
I should've gotten the autolec to do it when he set the Jeep up for towing, but I'll have to get him back to run another 6BS cable to the trailer socket.
I'll retain the wire from the power outlet as a switching wire for a relay to isolate the fridge when the Jeep isn't running.
-- Edited by mjt57 on Wednesday 29th of June 2016 01:32:39 PM
swamp said
01:39 AM Aug 3, 2016
HI
KeznGaz,
The situation is easily rectified
Lead acid 10 -20 % charge rate
AGM 20-30% charge rate
25amp redarc dctodc and solar as well ideal
from ignition solenoid switched in engine bay to towbar Anderson plug
good 13mm2 cable absolute minimum
better 16mm2
best 25mm2
Van Anderson plug to Dc to Dc charger
13mm2/ 16mm2
PRIOR TO THE DC TO DC ,JUNCTION OF TO FEED THE FRIDGE, VIA AN INLINE FUSE
Donot run the fridge power feed from the output side of the dc to dc as this will eventually overcharge the battery
eg the charger will never float and supply higher volts to batt constantly . FLOAT VOLTS ARE CRITICAL TO BATT LIFE .
** U do not want more than about 1.0volt drop in main feed cable . It effects every thing otherwise .
8mm2 cable is not acceptable
swamp
oldtrack123 said
10:41 AM Aug 3, 2016
kezngaz wrote:
What i also never mentioned was wanting the house battery fully charged when arriving at camp. if we were lets say free camping for 3/4 days then turning up with less than 100% charged batteries could be a problem.
We are also considering mobile solar.
Other than the fridge,which will run on gas,we dont realy have much more draw, leds and radio.
We think a second battery is is a lots of unneeded weight, so a 680gram charger would put us in good shape.
If we ever lived in our van full time then a second battery would still be easily charged with the bcdc.
Phantom.. How is your fridge wired, through anderson or 12 pin plug?
Delta 18.. think its auto 6mill as this was fitted to run smaller battery on old off road camper. Coupled with the style of alternator, something more upto the job needs to be done!!
If it is auto 6mill then you are wasting money even with a DC DC charger
Running a fridge from a dc /Dc charger that is trying to charge the van battery is not a good idea!!
The charger cannot read the true battery condition & therefore may not charge the battery correctly
The right way to run the fridge is from the tug battery with it's own dedicated 6B&S cables
But model number of the fridge is required to give correct details.
Even with modern alternators ,the fridge ,if correctly wired ,will get at least 12V & work to specs
Then use a DC /DC charger for the purpose it is designed for ,charging the van battery [with its own circuit]!!!
HI
KeznGaz,
better 16mm2
best 25mm2
13mm2/ 16mm2
swamp
