OH Dougwe, I hope that's not in your chief mate. That is dangerous big time.
Popcorn is on me for the next 20 seconds. Lmao
Middo said
09:42 PM Apr 2, 2015
Regarding testing of leads and appliances, there is no legal requirement for that to be done unless they are used for a business. However any caravan park owner can make it a condition of entry as part of their OH&S requirements
Pete
Baz421 said
09:46 PM Apr 2, 2015
Good thread Phil,,, see this for a laugh and see who you can see in this lesson, lol.
Pete
100% for that one Middo, however it's not such a bad idea if your appliances are getting a bit long in the tooth especially small motors etc as you well know.
As far as CPs go, some insist and some couldn't care less. I've found the council owned parks the worse, my run in with the manager Over the testing of my main feed was a council park.
Rock and a hard place mate.
Phil C said
09:51 PM Apr 2, 2015
Baz, you rock mate. Great post.
02:13 AM Apr 3, 2015
oldtrack123 wrote:
Aus-Kiwi wrote:
[1] admittedly in van there's not too many other earths..
[2 As I said it doesn't have to the earth wire .. we test with temp earth on domestic as its a known earth ..
refereing to
[3] earth trip is the old earth leakage circuit breaker type..
[4]power in the annex for example ..
As I said You may be surprised at how many" earths" are in the average Van ,camper ,motor home.
Sadly many are not aware that the following are more than likely to be "EARTHS"
[1]the whole chassis & any metallic objects attached to it that usually includes metal doors & windows & their frames ,If metal clad the skin
[2]the gas pipe lines & any gas appliance[gas stove]
[3]All class 1 appliances, fridge, aircon ,micro wave , toaster,electric jug /kettle ,etc
[4]Possiibly the stainless steel wash up sink & taps
The true situation would be that almost anywhere you stand EARTHS are within reach!!]
EVEN if the extension lead is not plugged, but a generator or inverter is plugged into the power inlet socket
The old ELCBs[1960s] as used in the general electrical area, worked on exactly the same principle as today's RCDs
They detect an out of balance in current between ACTIVE & neutral
The only way that can occur is by a leakage to" earth" in an" 'earthed" neutral system.
or the very remote chance, that one or the other legs within the ELCB /RCD is bypassed
Perhaps you are referiing to the EARTH leakage detectors used by supply authorities that warned of line leakages???
PeterQ
Just had a handfull of popcorn
-- Edited by oldtrack123 on Thursday 2nd of April 2015 02:50:15 PM
Not surprised at all .. Wow metals conduct ...
johnq said
02:48 AM Apr 3, 2015
Just When You Thought It Was Safe To Go Back in the Van.....
Family not accepting the excuse that every electrical appliance in the house is out to get me. Stacking the dishwasher on protest, but I will expect someone else to wait on me for breakfast -the coffee perc, toaster and so on...[more theme music from Jaws]
03_Troopy said
11:32 AM Apr 3, 2015
Phil C wrote:
Ontos45 wrote:
Snippet: Please remember that if you grab hold of a live wire you will not be able to let go. This will KILL you!
Depends on what side of neutral the sine wave is, one side it will grab you the other it will throw you away. Found out the hard way when an apprentice, was adjusting a slide on a Logabax mechanical computer and ended up across the room with a smoking melted screwdriver in my hand when driver slipped.
All electricity will kill, even DC, like the electric chair which is DC powered.
Currents with about 50mA through the chest region are considered deadly! Voltage higher than 35Volts overcomes the skins electrical resistance.
(Have my own coloured popcorn snacks thanks )
Hi Ontos, to qualify you post. (not sure what a logabax is though)
The time it takes for one cycle at 50 Hz is 20mS, trust me you cant let go (been there done that) it feels like 10 million very large angry ants crawling up your arm, I was lucky I fell backwards and the wire was ripped out of my fingers, thanks goodness for sir Isaac.
I was fiddling with an old B&W TV when I was 13, my Dad told me not to touch the trippler (which creates the very high DC voltage for the tube) I did and ended up with my bottom making a dent in the roller door of our shed. That was very large DC.
You are correct about 50mA, anything above that will start to "cook" vital organs, the frequency plus current will fibrillate the heart and give you a very bad day.
PS I like coloured popcorn too.
About 17KV from memory for the old B&W tellies. The big screen colour tellies could put out about 25KV or better.. A rough way to check the output was to see how long a spark you could draw out using a screwdriver grounded to the chassis. About 30KV per cm in dry air from memory. Luckily there is very little current with that voltage though, so not to much damage from the actual touching the EHT lead, it's the damage you do when you bang yourself about from the fright of it. Microwave ovens are bad though.. only about 5KV from memory on the Klystron, but enough current to take the tip off your best screwdriver if you accidentally touch it to the EHT. Worst i did was almost broke my leg when I fell off a stand while adjusting the klystron on the old Mirage radar, on the end of the strip during an exersize. We had some Malay pilots landing about 50M from where we stood and it made me a tad nervous and I accidentally touched the wrong bit.
12:42 PM Apr 3, 2015
Candles and Wood BBQ's.. Oh no !! Fire !!!
Phil C said
12:54 PM Apr 3, 2015
Wow, that brings back memories troopy, the old mirage. Never got to work on them but we were trained with their generator system and did a little on the cyrano.
15KV will most certainly bounce you on your butt, I got booted by 240 on a P3B on a test flight taking voltage readings in the main load centre, knocked me out and the test flight was aborted, spent a few days in the base hospital for a very large bump on the head and 10 stitches on my noggin, oh also hooked up to a heart monitor.
In those days there was very little concern for OHS. I saw a YouTube on some sumpies doing an engine change and fuel tank clean on a herc they had hard hats, breathing apparatus etc, good lord that was unheard of when I was in.
Take care mate, good to hear from you.
aussie_paul said
03:26 PM Apr 3, 2015
I guess I will get shot down. I grew up on a farm with a father that was very mechanical and did as much as he was capable of. He instilled in me to assume everything is dangerous and to think before conducting any job. I developed Diabetes at the age of 20 and farming, was a flat out one day and less so another. Back then Diabetes control was much more difficult compared to today. After Eril and I married we spent several years on the farm which also including losing our first baby at 3 weeks.
Eril and I decided that continuing with a farming lifestyle with my Diabetes was going to be difficult and I liked the mechanical and not the stock side of farming which included contract gravel carting from our Mount Emu.
So, Eril and I bought a run down Motel in Ballarat in 1976. I did quite a few minor things electrical, plumbing, and anything else that was required. We built some new units and of course there was an electrical inspection required. We had a retired man we used for odd jobs and looking after the business while we went on the odd holiday. This guy had a son who, with a partner, ran an electrical business. I thought I had better get them to tidy up any stuff that I had done. The business partner berated me sternly about some of the stuff that I had done!!!! Anyway all was good after the necessary work was performed and the new motel units were connected.
A couple of years later the guy that berated me was killed in a roof when he had his bare knees on a cold water pipe and he drilled through a live wire!!! So sad..
Phil C said
06:25 PM Apr 3, 2015
No gunfire from me Paul, just a sad story of how easy it is to get into strife with electricity or for that matter, anything. That can bite you.
when I was teaching we would get a mate from the office of the technical regulator to come around and show the apprentices what happens when we don't respect electricity, there were quite a few deaths in roof spaces, I hated crawling through them and wing tanks at the best of times
I hope you are better mate.
philC
03_Troopy said
06:50 PM Apr 3, 2015
When I had my Electronics Business, I used to do a lot of TV antenna installs. One of the things we get out this way is damage to wiring caused by rodents in roof spaces. One particular house I went to install a system in had been attacked by the said rodents (I'm told they're bush rats?) and had extensive damage to the 240V wiring in the roof space. To make matters worse, someone (I was told it was the previous owner) had made repairs by splicing three core flex in place of the damaged sections, covering the joins with black electrical tape. The scary part was, that being school holidays, I had my 17yr old (at the time) son with me to keep him from being bored at home.
The bloke who owned the house was pretty miffed when I told him I wouldn't install anything till he firstly got an electrician to repair the bodgy makeshift repairs, and he did something about the rats in the roof space as well. He was more worried about me telling him he had rats in his roof, than there was a distinct possibility his house could burn down LOL
DeBe said
07:40 PM Apr 3, 2015
Just a bit of brush up Phil, a Klystron is a low power Microwave local oscillator in a Radar. Havent seen one since the 60s, heres one out of an old Decca radar.
Yeh familiarity with the job is also a hazard. I ran about 18 Deutz - 10 and 25 and 1 X 55kVa gen sets at Pt Cook in the early 70's as the Vic power supply was so unreliable. 2 ran all the time while flying was on and the others as required. I was the blackhander and Smelly B was the elec fitter.
On a cold Pt Cook mornings everyone was rugged up and in a hurry to get back inside and warm up so often shortcuts were taken. One shortcut was to change 2 gensets connected together with one running so the 3 phase plug was "hot" on the standby genset.
Well Smelly came in one day very haggard,,, he was put on his arse as he tried a hot change over to connect a 3rd genset and so I could take the standby away for service. He was very very quiet and later stated he was sent back over 10m, with some minor burns,, but he wouldn't got to medical because of the ramifications.
This thread just gets better and better. We used the big gen sets at Gin Gin when 2FTS sent the flyboys out for a bit of Nav practice, then staged from Gin Gin till dusk.
There was a startup checklist that nobody paid any attention to, the WOE hit the roof when he found out and had all the ground crews paraded and dressed down, after that it took 10 mins to get the line cranking instead of 3, the cadets ended up starting on batteries.
Goes to show hey?
03_Troopy said
11:49 PM Apr 3, 2015
DeBe wrote:
This is a Magnetron in a Microwave oven.
Thanks DeBe, yep.. I said Klystron but meant Magnetron.. in the MWO
Magnetron in a transmitter, Klystron in a receiver...
-- Edited by 03_Troopy on Saturday 4th of April 2015 12:58:55 AM
Ontos45 said
11:14 AM Apr 4, 2015
Talking about rats, late 70's doing fault finding and cabling at Red Tulip factory Sydney, apprentice stuck his head in a brick wall cut-out and nearly lost his nose, talk about rats as big as cats and over the bloody mixing vats too. Boss called to ask why we taking so long, told him issue bloody hand guns and we be a bit quicker.
By the way, a Logabax was a French electro/mechanical accounting machine using 240VAC solinoids to move slides that rotated cogs, huge. Nock and Kirbys, Grace Brothers etc used them.
KFT said
11:25 AM Apr 4, 2015
Like this one Peter?
-- Edited by KFT on Saturday 4th of April 2015 11:26:07 AM
That's the bugger...seemed bigger back when a trainee
12:37 PM Apr 4, 2015
Sheesh that looks older than 70's .. We take it for granted how fast tech has gone..
Some hands on things have gone though ..
Reminds me of an Remington type writer I learnt to type on ...
In the 70's,...
Phil C said
03:38 PM Apr 4, 2015
Holy cow batman, that's old. When I was a tech in the PMG many many moons ago we used a similar technology, from memory a carpenter relay was involved and moved bars with notches to give the electrical pulses for the characters the old telegram machine.
Triple333 said
09:52 PM Apr 4, 2015
As controversial as this topic may be..... My caravan would have caught fire by now, if I wasn't an intelligent blond (I know, no such thing!!!!). And I may not be writing this.
Long story short, got an external 12v plug fitted, at my trusty rv servicing place. I have great hearing (it buzzed) the socket, and a gut instinct made me wary. Many dollars later, in another state, and it was lucky I stopped using that socket. The rv idiot had wired it to my external speakers, not the battery. It was already showing burn signs in the wires.Cost me $$$$$. I made the rv place pay me back. And don't get me started on the idiot that wired my car for brakes etc.
Both claimed to be experts. So how's a woman to know? Or anyone for that matter?
Another ex "TIT"
Worked on the Swedish Cross Bar Exchange in Lakemba Sydney, the mechano set we called it. Still remember though running around the old exchange with a butt watching for selector arms to move and get numbers, ohhh the noise...oh the fun....lol
Phil C said
10:26 AM Apr 10, 2015
Ontos45 wrote:
Another ex "TIT"
Good lord ontos, my first job as a TIT was to help pull all the step by step stuff out of Blacktown exchange As a TIT, then I ruined my new dust coat by taking SG readings as they commissioned a new battery bank. I joined the program in 1965 and started my training at Homebush. I was in section 1
Pete
philC
Magnetron in a 1980s Koden marine radar I still use.
Another lucky escape eh Phil.
Need one of these ..National licence to perform high risk work .. Lol
Goes to show hey?
In the 70's,...
This will put a spanner in the works!!!!
http://player.vimeo.com/video/38313889?portrait=0
One could call him a "Bright Spark"
Another ex "TIT"
