did I , I just purchased a 140 watt poly panel for $151, just look around .
pawsoz said
05:54 PM Dec 10, 2014
Did I, you have not mentioned your house battery, I guess you have a seperate deep cycle battery? How many amp hours?
Annie
SnowT said
06:15 PM Dec 11, 2014
Didi..
If your worried about the heat transfer of the roof you could try what I'm planing on doing..
- I plan to paint the Roof with a Thermoshield paint... if I get even 20% of the expected heat saving I will be please.. As I do park in the direct sun.. With the Tropical roof of solar panels to keep 90% of the roof shaded, it's going to be a saving....
At one stage I had a Tropical Roof over my Panel Van main area it worked well.. especially over the winter time...
Juergen
briche said
09:53 PM Dec 12, 2014
Hi Didi, don't feel bad about asking questions about anything. Solar Panels are one of those topics that everyone has had various experiences with. The advantage of this forum is that you will find the answers to you questions and that is what makes this forum so good. I still think for your current situation 2 x 80 watt portable panels with cover you for a large percentage of the time. You can always add another panel but you will need to ensure that the regulator is capable of handling the extra capacity.
BTW I have found a place where you can buy the Ctec regulator In Rosebud.
anyway see how it all comes together and don't worry about asking me about stuff, only too pleased to help
regards
briche
-- Edited by briche on Friday 12th of December 2014 09:54:23 PM
didi said
07:23 AM Dec 13, 2014
Thank you Briche. Really appreciate all your help. I thought about what you were saying about you having both solar on roof and portable (as you do) as being the best solution and I think I may go this way after all. I was looking at a 150w panel for the roof, but can I sit it right to the edge of the roof? And a 120w portable. Do they need to be the same brand? And Would I be best getting a 30w or 20w regulator?
Cheers Didi
didi said
09:27 AM Dec 13, 2014
Hi Briche. I already have a good battery charger and the Ctec seems to be both charger and regulator? Could you come and look at my regulator and see what I need, when you have some free time? Cheers Didi
Annie
Juergen
regards
briche
Cheers Didi
