You mayfind this copy of a post I just made on another forum of interest
It is relative to Dc /dc chargers & connecting a heavy load like a 3way fridge to the house batteries
"HI xxxxxxk
I am not sure why you say your FRIDGE would not work with a computer contolled alternator
Such an alternator Normally still puts out around 13.2V
If the VD in the cables to the fridge is limited to 0.5V, 12.7V should be more than ample for the Fridge to oprate as well as on the house batteries
It would be interesting to know what voltage you get from the D+ terminal of the alternator??
But you are correct , a computer controlled alternator will reduce the voltage below what could fully charge the house batteries by direct charging,especially with the extra voltage drop in the cables from crank battery to the house batteries
Your own figures indicate that only 17A is available for battery charging but since you only have 80Ahrs of battery capacity that would not be a problem IN YOUR CASE
IF those batteries were taken down to 50% SOC a 3hr drive alone would fully charge them
BUT if you had say 200Ahrs of battery capacity taken down to 50%SOC,You would have a different situation 100Ahrs / 17A =5.9hrs driving
But if the fridge is running from the alternator, AS IT SHOULD, the full output of the charger would be available to charge the house batteries
For those with small battery capacity & low daily use, it may appear to work well ,but the bigger the the battery charge required the worse it gets in engine run time
Those with a 20A charger may never get the batterroes charged
One other less detectable problem which can have an effect on battery life,
Due to load from the fridge holding the charger in BOOST mode
While they may be referred to as SMART chargers ,they cannot determine where the output current is going[they assume it all going to the battery
The batterries may be held too long at a voltage just under float [essentially OVERCHARGING them]
So as you can see what is good for the goose may not be good for the ganderor a case of horses for courses
Sorry but I simply cannot agree that such is a good idea or the CORRECT methodfor either the fridge or the house batteries
PS The Dc to dc charger does not fool the alternator into putting out more voltage,
it simply CONVERTS WATTS at a low voltage & high current into higherVOLTS at a lower curent PLUS CONVERSION LOSSES
eg :to get your 40A output at 14V you need to put in622W
divide by your 13.2V alternator voltage & the current draw from the alternator is 47.13A
But is you have just a 0.5Vcable drop, the current draw is even higher622 /12.7V =48.97A drawing 22.5% more AMPS from the altennator than is going into charging the battery
Even with DCto Dc chargers adequate sized input cables are required to limit losses. ""
PeterQ
oldtrack123 said
12:57 AM Dec 2, 2013
SnowT wrote:
Now this is WHY I need to Ask the Dumb Question..
Yes the Solar panels shall be Paralleled up..[the drawing was wrong in that Area..]
Ok I have more information for you.. I'd Rather go Over size, than under size..
Juergen
Hi J
The one metre run from the dc charger to the batteries will give0,078V drop at 40A with 5B&S[16.77mm2]
6B&S [13.3mm2 =0.099 Vdrop ,Which i would consider quite adequate
7B&S[10.55mm2] gives 0.124V drop
[2]I would certainly use the B&S 0 [53.49mm2] for the battery parallelling jumpers
[3] for the solar I would consider 6 B&S [13.3mm2]quite adequate with a0.099 VD
[4 ] similar for the Mains charger would be ok for a charger up to 40A
PeterQ
brian said
09:12 AM Dec 2, 2013
Oldtrack 123 said
Hi J [!} The one metre run from the dc charger to the batteries will give0,078V drop at 40A with 5B&S[16.77mm2] 6B&S [13.3mm2 =0.099 Vdrop ,Which i would consider quite adequate 7B&S[10.55mm2] gives 0.124V drop [2]I would certainly use the B&S 0 [53.49mm2] for the battery parallelling jumpers [3] for the solar I would consider 6 B&S [13.3mm2]quite adequate with a0.099 VD [4 ] similar for the Mains charger would be ok for a charger up to 40A PeterQ
Surely you jest????
All of the suggested sizes above are pure overkill.
I rarely specified links as large as 50mm² even for multi thousand Ah banks that we built.
50mm² has a carrying capacity of around 250 amps, and in a parallel connection the links are carrying only their relative proportion of the load, not sure that the OP will be dragging 500 amps from his 2 battery bank.
As a battery interconnection link, 8 AWG has a capacity of about 75 amps, so that would allow a draw of 150 amps with a voltage drop of less than 0.1v for the lengths specified, which is well within his likely loads.
Remember also that for most of the cables being considered here, the voltage drops are not cumulative.
oldbobsbus said
11:14 AM Dec 2, 2013
..LOL... Brian,
Between the 2 of them by the time Peter finishes up loading up the bus with wire and SnowT loads it up with everything he wants in it he will need a HR license to drive it it will be that heavy...lol
oldtrack123 said
02:16 PM Dec 2, 2013
brian wrote:
Surely you jest????
I rarely specified links as large as 50mm² even for multi thousand Ah banks that we [1]built.
[2]As a battery interconnection link, 8 AWG has a capacity of about 75 amps, so that would allow a draw of 150 amps with a voltage drop of less than 0.1v for the lengths specified, which is well within his likely loads.
Hi Brian
Yes the battery jumpers are on the large size but welding cable in that size is readily available
& possible connection losses also ned to be considered
& who know what size INVERTER J may finally decide on
I know different tables give different values based on a number of conditions
But a common table shows the continious rating of of 8AWG as 62A
Based on J's 100A [surge current?] the voltage drop under that condition would be 0.16V
At 150A, VD would be 0.247V!
But just one other point ,you say NONE of the VDs are additive, perhaps you shoul look at the circuit & reconsider THAT statement!
I have just checked my figures for the solar& Mains charger & correct them.
At 40A the vd to the battery terminial would be 0.1036V THEN there is the Jumper VD 0.03
total 0.1336V
Since the MAX recommended voltage drop with most solar regs being 0.2 V between reg a battery it is on the safe side allowing allowing for any connection losses
I think you would agree ,0.2V represents a significant difference in SOC of a battery
And the same should apply to the mains & DC to DC charger
Finaly what would be the COST difference for the small amount of cable involved ??
AND for Bob,the weight difference??
PeterQ
-- Edited by oldtrack123 on Monday 2nd of December 2013 02:21:35 PM
-- Edited by oldtrack123 on Monday 2nd of December 2013 02:24:13 PM
-- Edited by oldtrack123 on Monday 2nd of December 2013 02:36:27 PM
oldtrack123 said
02:19 PM Dec 2, 2013
oldbobsbus wrote:
..LOL... Brian,
HI
Another very useful post??????
PeterQ
oldbobsbus said
02:24 PM Dec 2, 2013
oldtrack123 wrote:
oldbobsbus wrote:
..LOL... Brian,
HI
PeterQ
Ditto
SnowT said
08:03 PM Dec 4, 2013
Bob I don't think I'm going to go to far overboard..
I just want to cover my Bases, I don't want to cause an issue down the track..
I've been trying to work my way around the Battery situation..
I'm Looking to have a 400+Ah system.. to give me a Large window of usage.. I might not need it Now.. but I would rather have the Excess NOW with out drewing down to much on the Batteries..[DOD of about 20%]
- My Load..
- Fridge
- Freezer[Possible]
- Cpap
- Lights
- Lap-Top Computer
- General Electronic Gear.
I have paper tested the Load.. and a 400+Ah system with about 700w of solar will give me A Huge reserve at the current Load, with out having to resort to generator[At least I hope]..
I have done a bit of chasing down Battery's.. was think'n of going..
DC210 12V 210Ah 65.5kg 525 x 209 x 218 Price: $637.00
DC260 12V 260Ah 89kg 521 x 269 x 224 Price: $785.00
- IF I went either of those 2 Batteries I would need 2 of them to get the 400+Ah
DC120 12V 120Ah 36kg 331 x 175 x 214 Price: $343.00
With this Combo I need 4 Battery's to get the 400+Ah
DC120 480Ah 144kg - $1372
The Price's Quoted are NOT the Best you can get..[Just a Reference]
Charger's
- DC/DC ..? Suggestion of the best for the task.. Redarc or CTEK
- AC charger.. ?? CTEK-MXS25 is the one choice I have seen..
Juergen
brian said
09:51 PM Dec 4, 2013
Juergen, the time is right to seriously consider LiFePo4 technology.
The weight saving is considerable for the same Ah, but you don't need as much Ah with them, and the total cost won't be that much different.
You can get away with roughly 2/3 of the capacity, again for the same usable Ah, they don't suffer voltage depression anywhere near as greatly, often holding over 12.5v even under sustained heavy loading, and because they charge so much more rapidly you can provide less solar capacity as well.
There are numerous knowledgeable folk on the forums who know the ins and out of these batteries, and who are quite willing to assist you along the way.
oldtrack123 said
10:48 PM Dec 4, 2013
brian wrote:
snip-------
[1] and because they charge so much more rapidly you can provide less solar capacity as well.
Hi Brian
All the snipped section of your post I go along with BUT
[1] DO you realy mean that???
PeterQ
SnowT said
11:01 PM Dec 4, 2013
Brian I'd Love to But The cost is What Kill's me..
I have a set budget... LifePo4's Would just Kill the budget..
Also at this stage weight is not a Major issue..
- I know I would be saving 100kg's of Weight but the Cost is to much at this stage...
If I have it down.. About 2x the cost of the 480Ah battery bank.. for a 200Ah
Juergen
brian said
10:47 AM Dec 5, 2013
oldtrack123 wrote:
brian wrote:
snip-------
Hi Brian
PeterQ
Yes I do Peter.
You don't need to be embarrassed to ask the question - if that's why you included this symbol.
As you should be aware, a lead acid battery is a very slow creature to charge due firstly to it's initial high internal resistance when in a low Soc, and secondly to the requirement for the charger to ramp down its charge rate to limit gassing once the battery reaches around 80% Soc.
It accepts a reasonable charge early on in the process but then slows to a trickle long before the battery reaches full charge. This trickle can last many hours before the battery is truly fully charged.
Often, even in the boost part of the charge cycle, and with high insolation, a lead acid battery is not accepting all of the available Pv capacity.
There are just not enough peak sun hours in one day to enable a low Soc LA battery to be fully charged by a Pv array that is sized (battery to Pv capacity) to just utilise those peak sun hours.
Because of the internal resistance of the LA battery, even in the early charge stages a solar panel is often putting out only a fraction of what it could be doing if the battery could only accept it.
To compensate for this, we then install more solar to take advantage of the lower insolation afternoon and next morning periods when the batteries could be accepting more than what the smaller solar could deliver. We then have larger capacity than the battery can accept at peak times, this is wasted.
It is a simple conclusion that utilising a battery technology that does not have this limiting factor enables the Pv collector to be smaller.
LFP technology fits this requirement, it can take all of the output that the panel can produce right up until almost full charge, and so therefore we don't need to add extra Pv capacity to compensate.
For comparative amp hours used, the Lithium technology makes better use of Pv capacity than the lead acid by a good margin. This logically leads to the need for less Pv capacity for the same Ah usage patterns.
Considering that LFP batteries have a longer deep cycle lifespan than LA types, can deliver larger discharge currents for longer with very little voltage depression, weigh considerably less and occupy a smaller footprint for the same usable capacity, charge faster, etc. etc. there is no doubt which is the better choice, and prices are getting down there as well.
oldtrack123 said
01:47 PM Dec 5, 2013
[1]As you should be aware, a lead acid battery is a very slow creature to charge due firstly to it's initial high internal resistance when in a low Soc, and secondly to the requirement for the charger to ramp down its charge rate to limit gassing once the battery reaches around 80% Soc.
[2]It accepts a reasonable charge early on in the process but then slows to a trickle long before the battery reaches full charge. This trickle can last many hours before the battery is truly fully charged.
[3]Often, even in the boost part of the charge cycle, and with high insolation, a lead acid battery is not accepting all of the available Pv capacity.
[4]There are just not enough peak sun hours in one day to enable a low Soc LA battery to be fully charged by a Pv array that is sized (battery to Pv capacity) to just utilise those peak sun hours.
[5]Because of the internal resistance of the LA battery, even in the early charge stages a solar panel is often putting out only a fraction of what it could be doing if the battery could only accept it.
[6]To compensate for this, we then install more solar to take advantage of the lower insolation afternoon and next morning periods when the batteries could be accepting more than what the smaller solar could deliver. We then have larger capacity than the battery can accept at peak times, this is wasted.
[7]It is a simple conclusion that utilising a battery technology that does not have this limiting factor enables the Pv collector to be smaller.
[8]LFP technology fits this requirement, it can take all of the output that the panel can produce right up until almost full charge, and so therefore we don't need to add extra Pv capacity to compensate.
[9]For comparative amp hours used, the Lithium technology makes better use of Pv capacity than the lead acid by a good margin. This logically leads to the need for less Pv capacity for the same Ah usage patterns.
[1o]Considering that LFP batteries have a longer deep cycle lifespan than LA types, can deliver larger discharge currents for longer with very little voltage depression, weigh considerably less and occupy a smaller footprint for the same usable capacity, charge faster, etc. etc. there is no doubt which is the better choice, and prices are getting down there as well.
Hi Brian
Let me start by saying those words I questioned would lead e some to believe that one could get more Amphrs out of lipfepo4s than they have put in
This has been a common problem since this type of battery started to mentioned on fora
Some of the apparent claims were absolutley ridiculous,even beyond perpetual energy
Claims have even been made they are 100% efficient in both charge & discharge cycles
Now
[1]Yes ,agree advantage 1 is they can accept a higher charge rate right through the charge cycle IF the solar capacity is there
[2]Yes, more so if only a PWM reg is used
[3]Yes,, more so if only a PWM reg is used
[4]yes, if the panel system is undersized & more so if a PWM reg is being used
[5]YES ,more so if a PWM reg is being used,
[6]I would expect that extra capacity to being suppling loads other than the batterries
[ 7] yes, I have no disagreement with that in itself
[8]Yes ,the technolgy does that, but usually during the day, you should have excess capacity so other loads can be run leaving the batterries for after hrs use
[9] by about 10to 15% I believe
[10]Yes, totally agree IF I was starting from scratch,&intending to keep the unit for many many years,I would be seriously looking at LiPoFe 04 batteries
I do nothave a problem with the batterries or the technolgy
I do have a problem which seems to pervade the subject of these batterries performing miricles
Many users make massively impressive claims, like i can run EVERY thing all day ,then give a list,yer when questioned on solar capacity to meet those claims go very quite!!
The part of your post I questioned could give that impression, IMHO.
One point that does not seem to be made is the care /control needed to ensure they are not OVERDISCHARGED or severely OVER CHARGED,that includes every single CELL in the bank
Over disharging a LA battery will shorten it's life, but will not kill it stone dead as can happen with LipoFe cells.
Over charging a LA battery can also shorten it,s live but nowhere near the effect over charging can have on Lipofe CELLS
The relatively flat output voltage curve of LiFePos means one has to work between narrow limits of SOC, or have accurate cell monitoring, alarms , or cell equalising methods
But I know you are aware of that, it is just for other's info
PeterQ
-- Edited by oldtrack123 on Thursday 5th of December 2013 01:51:15 PM
Plendo said
09:19 PM Dec 5, 2013
Hi Brian and Peter,
I have just read your summary, and it is good to see agreement about the benefits of LifePo4, just one little clarification, Peter you stated:
"The relatively flat output voltage curve of LiFePos means one has to work between narrow limits of SOC, or have accurate cell monitoring, alarms , or cell equalising methods"
While I understand what you mean it is a bit back to front.
The voltage of the LifePo4 cell stays relatively flat from 3.45V (95+% charged) down to about 3.18V (20%), multiply this by 4 for a 12v system, or 8 for a 24V system.
Add in voltage sag under load (small but still present), and voltage boost (depends on your charger) under charge and it does indeed become difficult to understand the SOC of a LifePo4 battery. By comparison you have to keep an LA battery in a narrower range of SOC to avoid reducing the life of the battery (which is already about 10% of LifePo4) but it is easy to tell where you are because the voltage drops through a much larger range.
The range of State Of Charge (SOC) you can use with a LifePo4 is typically between 95% and 20 to 30% which is very broad when compared with other common battery technologies.
oldtrack123 said
11:47 PM Dec 5, 2013
Plendo wrote:
Hi Brian and Peter,
HI Plendo
I believe we are saying the same thing regarding monitoring SOC of LiFePos
Yes, the depth of discharge that the LiPoFesCELLS can be taken down to to is quite low compared to any LA batterry BUT the very nature of the voltage curve[safe range of 0.27V] means it is relatively flat. until the cells are very close to being either fully discharged or fully charged
Remember it is the individual CELLS we need to be concerned about .,not the ovevall bank voltage
Working close to those limits allows litle range for errors.
At this stage the need for cell balancing is a bit of an unknown, IMHO, as few such batterries have had anywhere near the claimed live cycles in actual everyday use
Despite what some may say, CELL monitoring to limit the possiblty of over discharge & that resulting in reverse charging of an indivual cells is essential.
One cell in a bank goes too low it, starts to reverse charge virtually Stuffed , but when recharging others in the string will overcharge while trying to bring the string up to voltage !All stuffed very quickly
The situation is even more critical with series parallel set ups ,even a slightly minor variation resistance in the connection can be significant
Some users seem to be getting a liitle compla,cent because the cells have not drifted much out of balance so far , but most of those have only be in use a short time
It will be interesting to see how well they stay in balance as they age
But As I said IF I was starting over again, I would certainly be looking to use them!!
Sadly ,due to health problems THOSE days are over ,. just sold the motor home.
PeterQ
-- Edited by oldtrack123 on Thursday 5th of December 2013 11:59:54 PM
Plendo said
08:16 PM Dec 6, 2013
Hi Peter/Ralph,
after much research and help from others, I have purchased my cells to head down the LifePo4 route. I now have my setup running as a test setup, and I am glad I did not put it straight into a new van.
I have been watching the cell balance, and they stay consistent while they are in the safe range, but push them up into the top 5% and look out, invariably one or two cells will take off, similarly at the other end of the scale, when getting low in the voltage range they drift apart again.
For me the key is to keep them in the safe range, so I monitor at the cell level, alarm on high voltage, low voltage, and also voltage difference. Given the narrow voltage range, and the impact of voltage sag, and voltage boost the most reliable component of the alarm set is probably the cell difference alarm.
An alarm when the battery is high, it kills the charge, an alarm when the voltage is low it kills the load.
I have a couple more months to refine the controls before the van is delivered.
oldtrack123 said
11:53 PM Dec 6, 2013
Hi Plendo
Good to see you did not just jump in
Yes, you are on the right track , those sudden changes at each end of the charge/ discharge curve need to be kept well clear of
It seems YOU understand my post.
Also be aware that even a slightly dirty/ poor connection can upset the all apple cart If those low & high point monitoing points include those poor connections[false voltage readings]especially if taken when batterries have a load, or are charging.
To minimize the error, try to get the various senser leads DIRECTLY ONTO THE CELL TERMINALS
PeterQ
-- Edited by oldtrack123 on Friday 6th of December 2013 11:55:21 PM
-- Edited by oldtrack123 on Friday 6th of December 2013 11:59:00 PM
T1 Terry said
09:14 PM Dec 8, 2013
Let me first congratulate the sensible attitude that has developed when Li batteries are mentioned. Not long ago the mere mention of Li battery resulted in ridicule and a bable of mis information attempting to discredit a technology they really didn't understand.
It appears Brian has quite a good understanding of the capabilities of this technology and posted up a very good description of what can be expected.
I have a set budget... LifePo4's Would just Kill the budget.. Also at this stage weight is not a Major issue.. - I know I would be saving 100kg's of Weight but the Cost is to much at this stage... If I have it down.. About 2x the cost of the 480Ah battery bank.. for a 200Ah
Juergen
This is not correct, a 480Ah La battery will give a max of 240Ah if the load never exceeds 24 amps while still maintaining a 12v output under the 24 amp load, if the battery started at 100% SOC.
A 200ah Li battery will maintain a 100 amp output @ 12v or more for the full 200Ah if required, or 200Ah or more at a lighter load, but that should never be added into the capacity requirement calculation if you want the extended cycle life. If you are happy with 1,000 cycle of 100% of the advertised capacity compared to 700 cycle to 50% SOC with a drop to 60% capacity from the LA batteries then by all means calculate the required capacity using the advertised capacity as the bench mark.
The quality of the chosen AGM battery is really the question here, if you are happy with lower quality AGM batteries then its not a fair comparison between the useable Ah of cheap AGM batteries to the useable Ah of quality Li batteries.
Quality for Quality, Rolls or Concorde are considerably more expensive than Winston Li for a matched useable capacity.
As you can see from the above figures, matching apples with apples Li is far cheaper per Ah than AGM.
I am not endorsing any of the quoted suppliers, they are purely for reference value and you are welcome to Google search and prove my figures incorrect, but I very much doubt you will be able to find true useable Ah for AGM batteries at the quote price for Winston LYP batteries.
T1 Terry
-- Edited by T1 Terry on Sunday 8th of December 2013 09:16:18 PM
SnowT said
09:41 PM Dec 8, 2013
Hi terry..
Yes I do understand the short fall's of AGM battery's..
Initially I was looking at 480Ah batteries because I'm aim to use a Max of 30% of the battery capacity to run what I need.. My think'n is that the less I drew down the Longer the battery will last, therefore the Longer the life cycle of the battery..
I'm have done a bit of research regarding the Depth of discharge to charge cycle life.. and my initial thought's is go as big as I can afford to save in the long run..
I have just found the Winston batteries, but the question's are, I don't know enough to be able to full use the batteries to their full capacity and there is an extreme lack of information around.. The fact that the LeFePo4's have replace the first generation of Li Batteries is the biggest step..
I did do some rough pricing and I can get a 300Ah LFP for a reasonable Price But I'm not sure about the rest of the gear to be able to use them safely..
I'm still looking so I understand the full ramification's of Li batteries.. I DO NOT want to screw up..
Juergen
-- Edited by SnowT on Sunday 8th of December 2013 10:37:42 PM
beiffe said
07:30 AM Dec 9, 2013
Hi Juergen
You live in Victoria so have sent you a PM
Brian
coolabah1au said
07:47 AM Dec 9, 2013
Good morning how was the happy hour we had ours at anyson res last night ok
beiffe said
07:56 PM Dec 9, 2013
Still going Wayne.
We had a couple of hours then it was tea time so I am cooking some pies and then we will return to the fire to continue.
It is a hard life we live but someone has to do it LOL
Brian
SnowT said
08:44 PM Dec 9, 2013
Did the Math's[I hate maths]
- estimate 2400Wh per day.
3 days charge.
60% DOD.
I get 198Ah as the ideal Battery size.. 24v
Minimum Solar I need is 600, I plan to aim for 750+
It's going to be interesting
I'm also Looking at alternative forms of recharging..
Juergen
SnowT said
01:10 AM Dec 13, 2013
Hi All I wish to unofficially close this Topic..
Well I got the Answers I was after and wish to thank all who turned me around..
If I could formally close this Topic I would.. but I have been pointed in what I consider the right direction..
A bit more money to be spent on the battery system.. but a Heap of saving in the other direction..
As I have to say thank you to those that have helped me to simplify my choice's.. you know who you are..
Juergen
-- Edited by SnowT on Friday 13th of December 2013 01:11:24 AM
HI J
"HI xxxxxxk
PeterQ
Hi J
PeterQ
Surely you jest????
Hi Brian
total 0.1336V
PeterQ
HI
PeterQ
Ditto
- My Load..
- Fridge
- Freezer[Possible]
- Cpap
- Lights
- Lap-Top Computer
DC210 420Ah 132kg - $1274
DC260 520Ah 178kg - $1570
OR
Charger's
Juergen
Hi Brian
PeterQ
Juergen
Yes I do Peter.
symbol.
Hi Brian
Now
PeterQ
Hi Brian and Peter,
HI Plendo
PeterQ
Hi Peter/Ralph,
Hi Plendo
PeterQ
Hi terry..
Juergen
Brian
Brian
3 days charge.
60% DOD.
Juergen
Juergen
