Thanks Jeff, and the advice from you and other GN members.
peterphilips said
08:07 PM Nov 22, 2016
Epoxy Glue is the best for repairing your plastic water tank. Drain the gasoline from the tank and allow it to dry. Sand the area around the hole or crack and there after clean that area with a shop cloth saturated with rubbing alcohol. Mix the 2 part epoxy together and apply all around the perimeter of the opening.
