Now you've lost me. How different can the Adaptors be ?
08:16 PM Oct 20, 2011
I bought mine today, picked it up on my way home from Greens Lake. It is called a Powertech Plus (from Jaycar). Automatic Universal Laptop Power Supply for car use. 90 W and cost 59.95. 16 DC connectors included.
jimricho said
08:41 PM Oct 20, 2011
Identical to mine, Marj. If you have any concerns about selecting the correct plug I feel sure the guys/gals at your local Jaycar will help.
jimricho said
09:00 PM Oct 20, 2011
Sheba wrote:
03_troopy wrote:
Yes maybe... but.. an inverter is probably more versatile for running different equipment, or different chargers etc.
Mine runs 4 different camera battery chargers, 2 diffent laptops, a TV a soldering iron, an angle grinder.. hmmm... and anything else that has a standard 240V plug and doesn't dissipate more than about 600W.
-- Edited by 03_troopy on Thursday 20th of October 2011 06:57:13 PM
The original Post here was relevant to Laptops only troopy, not everything else you want to run as well.
-- Edited by Sheba on Thursday 20th of October 2011 07:01:10 PM
My summary was made in that context, that is for those deciding between a power supply or a PSW inverter to power the laptop.
If one has a need to power multiple devices and the additional power consumption is not an issue the inverter option could prove to be a better way to go as in Troopy's case.
09:52 PM Oct 20, 2011
This one I bought today is only for Laptops, nothing else so you really need an inverter for other things. I also bought a cig lighter connection to the in house battery, just has the battery clips on the other end of the cable. Just in case I want to use this and not the inverter if camped for several days.
Sheba said
09:59 PM Oct 20, 2011
If it's like mine, [different Brand though,] the Instructions will tell you which one to use for a 19V. Lap-top.
10:05 PM Oct 20, 2011
Yes Sheba, there is a list on the instruction leaflet.
