Thanks David, also John, for the info.
38ah for $130 is good value for the battery alone. I guess it's most likely a gel (SLA) battery. I notice the Projecta website doesn't list the 1500/33 ah so maybe it's a discontinued line. They do list a 2000/44 ah with 12/24v series/parallel switching which is not cheap so I guess it's a "commercial" unit intended for roadside patrols etc.
I have an auxiliary battery fitted to the car, 50ah capacity, (limited by space available) that I use to power a Bushman too. I was most interested in John's power consumption figures but for obvious reasons didn't enter into that conversation earlier. (wuss!)
I top up the charge when I have "ground" power available with a Ctek 7 amp charger, saves using a separate 240v power supply. My interest in the jump starter is give me some extended range. As I mostly camp in Caravan Parks I don't need to go to the expense of solar at this stage. I also have a "blue Tongue" compressor wired into the car so I don't need that function.
Yes the tug is an NP, diesel, manual, 2003 owned since new. I've had an excellent run so far (95k) only problem a burnt out clutch bearing (mea culpa, "guilty as charged Your Honour!"). The photo was taken near Colac on my recent trip to Victoria, the camper is a Goldstream "Goldcrown", similar to a Jayco Penguin...no pull-out beds. I'll be back on the road again on Monday for a couple of weeks, going up to Gladstone (Qld).
cheers,
Jim
Smokeydk said
06:23 PM Apr 15, 2010
Thanks Jim.....My NP..built in Sept 2005 first Reg in Jan 2006.....its an Auto...turbo diesel with too many thingys...like MATT and traction control and other weird stuff....I've had it 14 months its done 95k in new condition..
The Jumpstarters are a great backup
Safe travels
Dave
Pic 1 is of course the front and pic 2 is the back view.
The jumpack has a built in compressor and the leads are stored in the bag at the back.
-- Edited by JRH on Thursday 15th of April 2010 11:47:46 AM
