Australia direct 4wd drive and camping everything 12 volt related, I just watched a little vid on this site called,
PWM vs MPPT charge controllers educational video,but. I cant post the link if anyone can find it and post it here I think it would be a very good thing thanks ....
I was worried that you were about to start up yet another one for the Tech heads debating, no arguing, about the relative merits of pwm v mppt.
I'll have a look at the vid now to see what it says.
edit (after looking at the vid) ... Oops looks like I spoke too soon. I think that the vid might just spark off the usual discussion. BTW, I have a spare pwm controller that came with my Vic off Road panel. An mppt controller is built into my DC to DC charger so I didn't need the pwm one.
edit 2 ... here is a previous thread on the subject of pwm v mppt ... a lot of which I don't understand
-- Edited by Cupie on Sunday 6th of May 2018 08:21:30 PM
-- Edited by Cupie on Sunday 6th of May 2018 08:33:49 PM
Ron-D said
08:00 AM May 7, 2018
Thanks Cupie for the link I just wanted to see a tec report on the subject that was well explained and this one seemed to be right on the money ,theres no doubt in my mind now that mppt is is in a league of its own...
Farmhat said
09:03 AM May 7, 2018
Hello Ron_D. Interesting video, thanks for putting it up. It does explain differences however, the parameters used are biased, probably based on pulling in more sales of a more expensive unit. Warning bells started in their opening sequence, showing figures for a 300w 24v panel whilst showing specs for a 120w 12v panel. A bit later he sprouts a very one sided example that suits mppt. If you are regularly running deep cycle batteries down to 11v as in their example you have a much greater problem of having to replace batteries.
Lastly, few people run 200w to 300w panels on caravans etc as it is not prudent to do so, and do not run 2000w. Mppt's are used on large arrays such as on house roof installations where mppt is the norm.
It is just as possible to have an unbiased video with real life RV specs to show a more even difference between the 2 systems.
Joe
Ron-D said
09:25 AM May 8, 2018
Thanks Joe I see your using a pwm reg with your set up so obviously your happy with your reg,it would be interesting to see a report from a real techie on the subject,we have one here thats knowledgeable but he promotes pwm with his systems thats fair enough,but that goes against everything that I have read on the subject, it would be nice to hear from a techie that could give an unbiased slant on the Mppt reg ,I think from what I have read just about everywhere,most would use the more modern tec reg even on Rvs..
-- Edited by Ron-D on Tuesday 8th of May 2018 09:33:46 AM
Dickodownunder said
10:44 AM May 8, 2018
This post in the forum link that cupie quoted above pretty much covers what the lay person should be initially looking for.
..................................................................... Quote It has been shown, often, that the cheap MPPT regs like the one above are FAKES ! They may work OK as PWM regs but have no internals to boost the output current. furious There are lots of FAKES on ebay.
When I did my research the Tracer brand, available from a lot of suppliers on ebay and locally were the cheapest ones which actually work. I found mine worked well. They have a front meter to display some details and also have a remote meter available to monitor the functions, for a reasonable price.
Note that poor sized wiring will dissipate the extra power that they can make, in wiring losses.disbelief So if the wiring from the panels is minimal then just use a PWM reg and save the money.
Also note the MPPT reg current rating is based on the full solar power rating not just the panel current rating as the output current will be higher at some times.
PS I bought a cheap PWM reg recently for a simple job. It was advertised as a two stage reg but actually it was just a simple one setting reg with no float. They refunded a small amount to get it "fixed" when I complained. disbelief Plenty of fakes in the cheap end of the market !! I would not trust my expensive batteries to a cheapie.
-- Edited by Jaahn on Monday 20th of November 2017 08:28:56 AM End quote ...........................................................
There is many a subjective argument for and against each controller.
T1 Terry has contributed some good information regarding the use of PWM controllers and others disagree with him.
Terry is an installer and appears to have done a great deal of research as to what he recommends.
Terry also appears quite knowledgeable if you are thinking lithium.
I am not in any way affiliated with T1 Terry, I just like the way he explains things.
-- Edited by Dickodownunder on Tuesday 8th of May 2018 10:50:55 AM
Dickodownunder said
10:57 AM May 8, 2018
On my previous van I had a tech based in Adelaide that fitted 300w solar to 2 x 120 amp AGM's and I asked him about MPPT controllers and his view was that I was my money I was spending but for my situation the PWM would be fine.
His statement was that while MPPT was great on large house type installations the PWM would be fine on my set up.
I went PWM and it worked fine.
edit; just to make it clear I didnt use T1 Terry because I didnt know of him at that time however I believe Terry is a "real tech" as is the guy that fitted my solar.
Phone around and ask some "real techs" and form your own opinion from there.
If you have made your mind up on MPPT then buy a good unit and go that way.
-- Edited by Dickodownunder on Tuesday 8th of May 2018 11:04:07 AM
swamp said
05:44 AM May 12, 2018
HI
Quality Mppt work but donot have tobe a lot of dollars . My 30a MPPT EP solar --Tracer series low dolllars good performance . UNDER 200$
I maxed out my portable size otherwise to heavy 195w
I maxed out my fixed [no more realestate on roof ] 195w
In the real world panels donot always perform at 100% output all the time
SO
To get some performance back MPPT
400watts produces 22 amps +++ mppt 30% 28-29 amps [beware this only occurs when batt is more than lightly discharged]
oldtrack123 said
05:17 PM May 12, 2018
T1 Has designed his system around Li batteries, [Almost constant voltage]& Panels who's PPP is low & leaves little power for a MPPT to make use of
A rather complicated way to explain it is that his panels & Li batteries are very close to being IMPEDANCE matched which means the system is operating @ max performance
Impedance matching of sources to loads does require some advanced technical knowledge, not something that many average electricians would understand & of course T1 is not an electrician.
If you could keep the LA batteries fully charged little will be gained by a MPPT. But LAs are a totally different story, with the voltage dropping as they discharge.
The question one needs to ask themselves is .:
What is the best way to go ,
[a]Add more panels IF you have the space & weight allowance & use a PWM or the extra cost of a quality MPPT??
Of course IF if you do not have the roof space or weight allowance that option is out
HE is not comparing apples with apples!
Many of us have tried to explain that to him for a loooong time A quality MPPT with suitable panels will ,overtime ,outperform a PWM. when used with LA batterries The fact that every roof top solar system uses MPPTs is so they get the max available output from the panels
-- Edited by oldtrack123 on Saturday 12th of May 2018 05:25:41 PM
Dickodownunder said
10:37 PM May 12, 2018
Mmmm...
Real techs???
Ron-D said
09:17 AM May 13, 2018
Good post oldtrack thats a very good explanation.
Cupie said
10:53 AM May 13, 2018
I agree .. except that I had to re read it a few times before I got it, ie LA means Lead Acid. Then it all made sense.
"Impedance matching" ... gee that term takes me back 1/2 a century or so when I used to try to teach barely understood principles to very un-interested trainees/apprentices. The only way that you could gain their attention was to say 'now this would make a good exam question'. Up would come the heads & they would start scribbling furiously for a bit before nodding off again. Unfortunately I too had been just like them & only learned enough to get the 60% pass mark so my knowledge was paper thin. Add to that is that my memory is piss poor.
oldtrack123 said
12:47 PM May 13, 2018
Hi Cupie
You were a naughty boy you should have worked harder
I had a good start in my tech life
My father was an Electrician & radio mechanic
From a very early age I use to sit & watch him doing radio repairs Asking questions all the time & even reading his Radio magazines & books
All stood me in good stead when I started my electrical apprenticeship , got honours or credits in every exams
I knew a lot more about electronics than any of the electricians or more senior apprentices & by my third year was doing ALL the company's service work on products they sold & they sold just about every thing for engineering
such as :
resistance welders With timers
Electronic flame failure devices
Photo electrical devices
Instrumentation of all type
Westinghouse /Mc Kensie & Holland rectifying equipment
Westinghouse /Rosebery switchgear & motor control systems ,electrostatic air cleaners & many other of their products
Brown & Boveri instrumentation & controls
& that is only about half the list
I also started doing an Electrical engineering diploma course but after a few years had to give it up as I was on 24hr a day callout for the service work just could not handle it all & the company's Electrical Engineer & a director reckoned I was more a hands on person [which was true] & that I had a job for life with the Co.
That turned out to be true retired from them age 60Years ending up as a works manager
-- Edited by oldtrack123 on Sunday 13th of May 2018 12:59:58 PM
Cupie said
10:17 PM May 13, 2018
Gone are the days of 'a job for life'.
I too was a single company person ...
Started at 15 1/2 yo and finished at 57 1/2 yo.
Had a great time working with great people in what was in those days a very good Company.
In the process I had at least 3 quite different careers all within the same organisation.
Started near the bottom of 60,000 + employees & ended up in the top 400 of admittedly a leaner organisation of about half that size.
-- Edited by Cupie on Sunday 13th of May 2018 10:18:04 PM
T1 Terry said
06:12 PM May 20, 2018
A few interesting bits in that video, the first bit @ 1.13mins shows a label from the back of a set of 3 panels that they sell. The specs are all STC ratings from a light box flicked on for a few secs and the panel temp at 25*C, yet a little further down the listing they show an NOCT of 47*C+/- 2*C so they are admitting the panel doesn't actually operate at 25*C yet they show no NOCT output readings, so you can take the outputs listed on the label with a grain of salt.
At around the 6 min mark it gets even more ridiculous, using their suspect figures the 100w panel will run at close enough to 100% efficiency. No MPPT manufacturer claims better than 80% panel efficiency, the 97% efficiency they spec is a cherry picked figure showing the difference between power in and power out, so they are really saying at the very best they are 3% inefficient or will waste 3% of anything that comes in .... and these are their very best figures, not the average or the worst, ya gotta wonder right there eh :lol:
The fact that no one in their right mind discharges their battery down to 11v regularly and the fact as soon as you start charging a battery it won't remain at 11v seems to be completely over looked.
A genuine video with 2 identical solar panels charging 2 identical batteries, one with a quality PWM controller and the other with a similar priced MPPT controller would show the reality rather than the nonsense, even swapping the batteries over between one and the other, then the solar panel between one and the other to clear up any doubts about one battery or panel being better than the other.
As far as using 24v or 36v panels to charge 12v batteries, why would anyone want to do that? You can't fit a grid tie solar array on the roof of a caravan that has a TV antenna, air con and a few vents fitted, so no point in pretending that you could buy them cheap and use them. Unless you can fit a decent array of large identical panels on your RV roof you can't connect them in series either, so no gain to be had with smaller cabling yet all the problems with high voltage feeding back into the panels and destroying them .... I have a few photos for those that don't believe it happens and I'd be happy to post them if anyone wants to see them.
T1 Terry
T1 Terry said
06:29 PM May 20, 2018
Really Peter? Are you sure you don't actually mean grid tied solar systems rather than all roof top solar systems? If you have 5kW or 10kW or 15kW of solar on your RV and feed it back into the grid rather than using it to recharge your batteries then listen to what Peter has to say. If you don't then ask to see Peters side by side actual real life testing that backs up what he is saying actually applies to RV size systems charging lead acid batteries.
T1 Terry is an Automotive Mechanical Engineer and part of that training involves extensive hands on knowledge involving the use of 12v and 24v battery systems. To get a 97% entrance exam pass into the Institute of Automotive Engineers and to hold that membership for over 20 yrs means you need to know a lot about DC voltage, wiring and batteries, very few licenced electricians would get a pass level in extra low voltage DC knowledge. That is where the problems seem to occur when an ex sparkie who spent most of his time in the office ties to apply what he thinks he knows to answer a question rather than applying knowledge he has gained actually testing his theories in a real life situation using the actual equipment used by the average RV owner. There is no value in using a controlled power supply as the input and a controlled load as the output to verify the value of any particular controller, you need to use actual solar panels and actual batteries to get genuine results.
T1 Terry
T1 Terry
oldtrack123 said
07:33 PM May 20, 2018
T1 Terry
T1 Terry
Oooh that nasty DC stuff , real electricians don't know about it ,but an auto mechanic does!!
There is it is folks NO Real Electrical experience , No electronics knowledge , but Lots of knowledge about those very complicated things called batterries even the nasty 24V ones. And low voltage solar panels
Not even an Auto electrician.
I wonder when Terry will accept that the basic electrical principles applies to EXTRA low voltage DC & are the basics of every electrical apprentices first year apprentice ship .
THAT is how complicated it is .And why no license is required to work on it.!!!
Terry does not like theory for one simple reason it is beyond his understanding, as many of us have seen with his posts here & elsewhere
Terry , I have given you the compliment of having experimented with & developed a system that is very suitable for use with LI batteries., in the van & motor home situation , but the red herrings are jumping every where ,trying to escape from your posts.
Lots of words do not indicate real knowledge but are commonly called Bull S*#t, though they may fool those who do not know /understand the real facts
For those who do not know , T1 interest in Lis & solar started about 5years ago from memory
.Compare that with some one who has spent a life time dealing with all types of electrical equipment ranging from Extra low voltage Dc & Ac up to thousands of volts Dc & AC
On two other forum , he demonstrated his lack of basic electrical theory & simply could not accept he was ever wrong
Those Forums have some very qualified people on them, but T1 took the same attitude there as he does here ,
In the end he was removed from those forums.
Every one who does not agree with him is denigrated ,no matter what their qualifications.
PS I am not sure where you get the idea that I spent most of my time in an office that is total BULL S--t
But I will repeat the compliment I made previously
T1 has EXPERIMENTED & developed a system that is very suitable with LI batteries , much of that is due to the relatively constant output voltage of LI s over their working range, plus panels whose MPPT point leaves little power for a MPPT to convert .
No Magic , No voodoo just very simple basic electrical principles. [perhaps beyond a first year electrical apprentice but certainly should be well understood by 3rd year
-- Edited by oldtrack123 on Sunday 20th of May 2018 07:39:20 PM
-- Edited by oldtrack123 on Sunday 20th of May 2018 07:53:06 PM
T1 Terry said
04:08 PM May 21, 2018
Sadly Peter you don't know near as much as you think you do. An auto electrician is a part of being an Automotive Engineer, an Auto Electrician only gains a partial licence where an Automotive Engineer is tested and licensed in all aspects of the trade and must pass very stringent testing in all of the fields to gain a full membership into the Automotive Mechanical Engineers Institute, to get a 97% test result means you need to know and understand all the subjects. Let's face it, if they train 1st yr sparkies in the extra low voltage field they all either forget what they learnt or weren't taught very well to start with. A sparkie considers 5% voltage drop to be well within the acceptable range, anyone who is skilled in extra low voltage work knows that is far from acceptable, yet the sparkie who wired you RV will argue till they go hoarse the wiring they used is adequate.
Peter, I don't dislike the theory side and I did gain high level passes in the Advanced Diploma in Electrical and Computing Technology and that does include a number of elements in the electronics field as well as AC & DC extra low voltage, low voltage, high voltage and 3 phase power. However, I do argue with those who rely on the theory side and don't test their theory to determine if they actually have the correct numbers in their equations, this will always result in an incorrect theoretical answer, garbage in will always result in garbage out. Until the theoretical equations can verify your theories with actual test results using the actual equipment used by the RV owners you are try to look clever in front of, I will continue to call out your theoretical results as B/S because you simply do not understand the dynamics involved. That requires yrs of experience with extra low voltage work, not sitting in the office writing technical jargon for those who are really doing the work.
The problem you have Peter is to get any confirmation you ever actually worked hands on apart from during your apprenticeship you would have to disclose your real name and not the pseudonym you use on line. Anyone enquiring about your expertise using your real name may well find many who would not agree with your opinion of yourself or uphold your claim regarding actually working in the field in the disciplines you claim you have worked in. On the other hand, I use my real name and my work is open for all to see and comment on both from the outside looking in and from actually using systems I have designed that can either confirm my skill level or deny what I'm putting forward as not working the way I claimed.
T1 Terry
-- Edited by T1 Terry on Monday 21st of May 2018 04:09:02 PM
oldtrack123 said
10:46 AM May 22, 2018
T1 Terry
Desperation now showing & with lots of garbage
I'll let others on this & other forums determine the extent of my knowledge & skills [especially those who have the qualifications to understand & decide]
But I will not further debate on any subject with YOU,as it seems to be pretty useless!!!
-- Edited by oldtrack123 on Tuesday 22nd of May 2018 10:59:01 AM
T1 Terry said
03:46 PM May 22, 2018
So you won't give your real name on this forum either Peter. For those that don't know, Peter gets real nasty when the people he is attacking start dropping bits of his real name into their replies. Seems Peter needs to hide behind a false name for some reason yet expects people to still trust that he knows all he babbles on about. Probably best to stay out of these type subjects until you actually have verifiable data to back up your theory talk, just because it looks good on paper doesn't mean the end results will match the hypothetical findings and to date you have never shown any actual photographic evidence of your experiments that back up you hypothetical chatter.
For those who enjoy a laugh, check out some of these videos www.youtube.com/channel/UC9v7v79mAlvKCrjrJvj-Fww where really smart people twist findings by other people into supporting their ad hoc hypothesis, the catapult baby is a good one as well as the alternate view on the handshake :lol:
T1 Terry
oldtrack123 said
10:58 PM May 22, 2018
T1 Terry
Best be careful Terry " It seems Peter needs to hide behind a false name for some reason yet expects people to still trust that he knows all he babbles on about. "" You are sinking pretty low now
And "Peter" is the name ALL my friends & family call me, But my birth name & location are readily seen on this forum , so again you are starting to look like a desperate idiot
You use your real NAME ,NOW, ON this forum to advertise your business.!!!!
I let others, who have a lot more knowledge & qualification than you ,to decide if I am just a theorist
But your true believers should start to have a good think about what you really know.
I doubt you could even past a 3rd year electrical apprentice test
They should also wonder why you no longer post on some similar forums
You know the ones you were kicked OFF because of your attitude , when others tried to explain the real facts to you
My working life was working on probably the biggest range of electrical equipment than you could even imagine.
Far from spending my life sitting in an office doing paper work, don't know where you got that from!!!
So I don't know on what basis you keep posting that bu**"£t .
Oooh by the way that video is great
I,'m sure the babies name begins with a T
-- Edited by oldtrack123 on Tuesday 22nd of May 2018 11:19:59 PM
12:10 PM May 23, 2018
Oldtrack123 and T1 Terry.
Obviously both of you cannot be correct when it comes to questions asked ... and obviously both of you cannot be wrong.
However, whilst your boyish tantrums back and forth are entertaining and almost amusing, they don't provide any confidence in solutions/advice/information to the question/s asked.
In some way, they rarely provide anything that the layperson can understand - let alone for the layperson to evaluate as applicable to the solution/s being sought. Especially when the responses wander off into who has the biggest testicles.
I do concede that often questions asked by members are unclear and lacking in specific information but the responses bounced back and forth rarely give a precise, specific, understandable, applicable answer to a question often asked in innocence.
Cheers - but keep up the chest thumping between yourselves ... if nothing else, it is amusing - John
T1 Terry said
12:31 PM May 23, 2018
Glad someone is enjoying it, Peter doesn't seem to be :lol: Never mind, I doubt there was much more to add when the whole thread went south or what ever direction threads go when they loose their way, but if anyone wants me to explain something I've posted in clearer English I'm happy to do that if it helps clear up any foggy spots.
T1 Terry
Ron-D said
04:53 PM May 23, 2018
I dont think your enjoying this pee-ing comp either Terry if your honest about it...but I am ...
-- Edited by Ron-D on Wednesday 23rd of May 2018 04:57:41 PM
T1 Terry said
05:08 PM May 23, 2018
I'm waiting for Peter to change direction and start digging up I need some entertainment while on rest breaks trying to get all the aches to settle down so I can do a bit more so the on going battles with Peter are a great distraction ... and probably keeps Peter entertained as well.
Every so often a bit of valuable knowledge gets mixed up in these typing battles so it makes for good practice for all sorting the wheat from the chaff, as the knowledge base grows the chaff gets easier and easier to identify
T1 Terry
-- Edited by T1 Terry on Wednesday 23rd of May 2018 05:09:14 PM
05:14 PM May 23, 2018
T1 Terry wrote:
SNIP~~~ Every so often a bit of valuable knowledge gets mixed up in these typing battles so it makes for good practice for all sorting the wheat from the chaff, as the knowledge base grows the chaff gets easier and easier to identify
T1 Terry
Surely you do not seriously believe that
Whilst I get a level of amusement from the boyish banter between you and Oldtrack123 - I really only see the chaff and very little wheat ... let alone useful information.
Ron-D said
05:29 PM May 23, 2018
I think its harmless banter. John ,although I understand where your coming from ,look at the post count its been a very interesting debate ,by two well educated guys that hnow each other well.theres not a lot of tec info but heaps of entertainment, just my view and I could be wrong...
-- Edited by Ron-D on Wednesday 23rd of May 2018 05:32:42 PM
Bill B said
06:15 PM May 23, 2018
Neither does their credibility much good with their ongoing pi$$ing competition.
oldtrack123 said
06:16 PM May 23, 2018
Hi Ron
Glad you see it that way
But I think Terry will win out
I'm loosing my stamina & concentration & loooong posts like Terry's are getting beyond me,
Too much having to read backwards & forwards & type correcting
Age is starting to take it's toll, but still cannot complain too much with 90th birth day coming up this year
Is this the one?
https://www.australiandirect.com.au/video/pwm-vs-mppt-charge-controllers/?gclid=EAIaIQobChMIsJvw6Onw2gIVVB0rCh2cOAFZEAAYASAAEgIiDvD_BwE
http://thegreynomads.activeboard.com/t64129951/pwm-or-mppt-controller/
Joe
Quote
End quote
SO
Real techs???
Hi Cupie
such as :
T1 Terry
T1 Terry
T1 Terry
T1 Terry
T1 Terry
T1 Terry
T1 Terry
Hi Ron
