check out the new remote control Jockey Wheel SmartBar Canegrowers rearview170 Cobb Grill Skid Row Recovery Gear
Post Info TOPIC: Solar controller limit..
Does a solar controller limit/clip the current to the battery when the current reaches then goes past the controllers advertised level, eg Morningstar pro star 15?
Aussie Paul. smile
Depends on the controller, a Plasmatronics PL series or Dingo series actually has a programmable upper limit that can be set to less than the rated capacity so they are designed to handle that task, but that doesn't mean all are designed that way. If the controller does have that capability it will create heat if it clips the max current to stay within its designed operating range. Depends how far over the controllers limit you go as to how much heat is produced. Best to read through the manufacturers specs and ring them if it is still unclear because some controllers will just let the smoke out if you try to push them beyond their limits.
T1 Terry
T1 Terry
Thanks Terry. I am still running our 320 solar watts through the Morning star 15 and it has not let any smoke out. lol. I have an el cheapo 30 amp PWM to fit as soon as I can find the energy to swap it over.
I guess when the panels start charging in the morning at the lower sun angle the batteries reach float without the full 320 having to go through the controller?
Aussie Paul. smile
Hi Paul,
Except for freak conditions where the sun reflects off the water or snow and back into very fine cloud and back down again, you won't see much more than 70% out of the 320w and at 12v that comes to 18 amps, so you aren't too much over so not really anything to worry too much about. Those freak solar condition days are the ones where it really hurts the eyes not to have the sun glasses on, rare but they do happen.
T1 Terry
Hi, I have a prostar 15, this is a 4 stage battery charger connected to 100amp agm
The battery setting is on 3 , better float voltage
I have a 200w panel on roof and 120w portable via ando plug , both connect to the prostar
have never see it go above 14.5 amp when charging
if you have a look at manual it says it can go 25% over output
It also has a over charge cutout
Also to remember the 200w is flat on roof so because of the poor angle it is really only 150w panel
So cant see it every being a problem
