check out the new remote control Jockey Wheel SmartBar Canegrowers rearview170 Cobb Grill Skid Row Recovery Gear
Post Info TOPIC: Jam Patty Tarts
Jam Patty Tarts
Found this recipe in a Women's Day quite some time ago, but we just love 'em - mind you doesn't do the waistline any good though.
JAM PATTY TARTS
340g pkt butter cake mix (B&G one is good)
5 1/2 sheets froz puff pastry
1 cup raspberry jam
icing sugar, for dusting (there gone before I get to this stage)
1. Preheat oven to hot, 200 deg C
2. Prepare cake following packet instructions
3. Using 6.5cm round cutter, cut discs from pastry, reserving offcuts
4.Line 4 12-hole patty pans with pastry. Place 1 tsp jam into each pastry case. Cover with a Tblsp of cake batter
5. Using reserved pastry, cut 1.5cm circles and place one of top of each patty cake
6. Bake 12-15 minutes, until puffed and golden. Allow to cool in pans. Dust with icing sugar to serve. Store in airtight container.
Makes 48       Prep Time: 30mins        Cook 15 mins.
Now for MY tips:
As the B&G cake mix uses 2 eggs, you can quite easily only make up half at a time, and with only half the cake mix made you only need 1 1/3 sheets of pastry to make twelve tarts using an egg ring as cutter. I also only use about a dtsp of cake mixture in each tart. As regards the round 'tops' - blow that, I just cut little squares out of the bits of pastry from between the main circles for the tarts and place them on top.
Oh, and you can use any jam you like.
Pejay are travelling in a 2014 Holden Colorado LTZ Twin Cab Ute + 2013 Coromal Element van
Thank you so much Pejay for not saying " Jam Cup Tarts."  I get so fed up with people using American Terminology for Patty Cakes, among other things.
We're getting far too Americanised.  At this rate, we should just become another American State.  We are Australian.  We should be using our own terminology.
Rant finished.
-- Edited by Sheba on Wednesday 27th of August 2014 05:51:52 PM
Hi Pejay, these sound like great tarts so will give them a go.Could you tell me if the 200c is fan forced ,if not do you know what to set the temp on. Thanks Mrs T
Hi Sheba,
No worries about the rant - think the same myself. Some time ago I purchased a cup-cake maker from Aldi - man, it is fabulous!! However, I still call them patty cakes/tarts. I like making little savoury thingy's in it, not just sweet ones that really are no good for the waistline, particularly when you are still trying to find your waistline in the first place!!
Hi Mrs T,
No, it is for an 'ordinary' oven, because you need the higher heat for the puff pastry. Not sure what the differences in temp. are for a fan-forced oven - sorry.
PJ do you think you could share some of the savoury things you do in you "Patty" cake maker. I loooovvvveeee sweet things but not so good for me as I get older. I would appreciate it Jen
Finally managed to find some time to add some savoury 'thingys' - have put them on a separate thread. Hope you enjoy them.
Rant finished.
Hear,Hear.
Far and away,too much Americanisation,going on in this Country.
Retired Electronics Tech
Amateur Radio Callsign VK2CJO
